I love that smell.....templ8 wrote:Haha yes it does smell a bit, my clothes stink of thinners
Bellypan
- agentpineapple
Re: Bellypan
Re: Bellypan
Very nice indeed will look great on your storm
Re: Bellypan
Kitted out with heat reflective foil
Re: Bellypan
Looks a proper job that well done
Re: Bellypan
Finally got it fitted after flatting with wet & dry then mopped with cutting compound and polished.
Looks very different.
- agentpineapple
- darrenmartin
Re: Bellypan
That's a great job, wish I had your painting skills (and patience)
Re: Bellypan
Where did you get the heat resistant foil and he is it fixed to the belly pan
Re: Bellypan
Thanks for the compliments.
The colour match is as close as can be without allowing for fading of the original paint, in the workshop the fluorescent lights make the new paint seem a touch darker but in the sun I can't see any difference.
The heat proof foil is off ebay, a 1000mm by 500mm sheet fits with a little spare. It's self adhesive and is only a mm or so thick so it's fairly easy to fit.
Re: Bellypan
Thanks for the info - I also have a white belly pan that needs making that lovely dark metalic blue !!!!
Re: Bellypan
Couldn't find the foil on ebay?????
Re: Bellypan
that's looking very smart mate
is this one the bellypans that comes without brackets?
if so what have you done re. fitting it to the bike ? ?
cheers
cheers
Re: Bellypan
Ebay item 181553647952 is the same stuff. The guy I bought mine from must've been a one off, he has no listing at the moment.
It's a bellypan from Norfolk moldings and it comes with brackets.
Re: Bellypan
Nice job.
Im lucky....
I do it for a living and have access to the right gear.
You need an air assisted mask for two pack paints. You'll get away with a cartridge filter mask out doors only.
Roger
Im lucky....
Roger
