Got the linkage off pretty easily, but how do I get the needle bearings out without the proper tool?
They're frozen in a bit and it looks like there's a stop that prevents the two bearings being pressed in too far. So I can't get a drift in.
Anyone got any tips? Couldn't find anything in the link servicing post.
Swing arm linkage help needed
- freeridenick
Re: Swing arm linkage help needed
With a long thin drift you can get in to knock one side out then the other side is easier to do.freeridenick wrote:Got the linkage off pretty easily, but how do I get the needle bearings out without the proper tool?
Can't remember what I did mine with but it was something like a bar from a socket set for a 1/4 inch drive T bar. A long flat blade screwdriver would do the trick.
Made a tool to drift out bearings. Stepped end to fit inside old bearing. Shouldn't be anything to stop bearings being pushed out. Pm your email & i can send a picture.
Heat will help, too.
The aluminium alloy housing will expand more then the steel bearing.
A heat gun should do, you would be surprised how good they are for jobs like that.
Handy to warm your hands too
- freeridenick
So I should be able to drift both bearings out the same side? I wouldn't do that, but there's nothing to stop the bearings moving too far towards the middle. Just so I'm clear.
I'll give them a good soaking in WD40 and see what happens. The bolt was easy to get out compared with some I've read about on here.
Thanks everyone.
Thanks everyone.
I took a stubborn seized bearing to bike shop which had a hydraulic press to remove it and put a new one in.
[quote="freeridenick"]So I should be able to drift both bearings out the same side? I wouldn't do that, but there's nothing to stop the bearings moving too far towards the middle. Just so I'm clear.
Thanks everyone.[/quote]
No you do them one side each.
Poke your chosen drifting implement through one bearing to knock the other one out then turn it over & drift out the remaining one.
- freeridenick
No joy after much soaking in WD40 and some 'gentle persuasion', so I took it to my local garage. Sorted in half an hour.
When they went, they went with a bang apparently, so there's no way I'd have got them out at home.
Back on the bike this weekend hopefully.
