single throttle cable mod ??
I've read somewhere that it's possible to remove the return throttle cable and have just the one supposed to give a lighter snappier throttle response well I took the clip-ons off today to have better look re fitting flat bars, so I'm thinking while it's in bits I explore this cable removal malarkey, now this may be dumb question but is it just a matter of removing the said cable or is there more to it?
I've now gone all European and bought a KTM Superduke GT and Aprilia RSV1000R
Storm is now gone
Storm is now gone
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Re: single throttle cable mod ??
Just whip it off, job done...
Although some plug the hole left in the throttle housing on the bar...
Simple as that, good I like simple and yes I think a grub screw would be wise in the soon to empty hole on the housing stop dirt entering, I'll have a go tomorrow,MacV2 wrote:Just whip it off, job done...
Storm is now gone
Storm is now gone
And oil/grease the spring on the side of the carbs, which will then be your only means of closing the carbs.
when you say simple...
Tank off, air box off, take the top of the throttle housing off. Loosen off the adjusters at the carb end, remove cable at that end, back up the top remove that end. Feed the cable out...throw it at the bin. Lube & adjust remaining cable if ness whilst its all open. Put it back together.
Should be simple but I bet a cyber £ that at least one screw/bolt shears/snaps/rounds off...
Would that be a Scottish cyber £
does give a much better throttle actuation. but as stated previously, make sure everything on your setup works properly as you will no longer be able shut the throttle closed. althought you shouldnt have any problems because for 90 years, bikes only used one cable ( my 89 gixxer 750 only uses a pull cable) it wasnt until everybody got so into lawsuits that layers made them put a push cable cable on there. its a pretty heavy duty spring on the carb and has no problem snapping the throttle shut. even if its not freshly lubed
I'm guessing none of you guys have ever had a throttle stick open, it's not a nice experience. Personally I'd go with a quick-action throttle instead,
or leave it sticky so you can get a cheap cruise control.tony.mon wrote:And oil/grease the spring on the side of the carbs, which will then be your only means of closing the carbs.
Mid corner'm guessing none of you guys have ever had a throttle stick open
![EEK! :eek2](./images/smilies/eek.gif)
QAT makes no difference to the opening and closing as it works on the same principle.I'd go with a quick-action throttle instead,
I do both. Quick turn and single cable.sirch345 wrote:I'm guessing none of you guys have ever had a throttle stick open, it's not a nice experience. Personally I'd go with a quick-action throttle instead,
Ive had a throttle catch wide a couple of times on trail bikes. Clutch solves it. Gives you the time to hit the kill switch.
HRC throttle tube fitted, return cable deleted, everything lubed and feels nice, smooth opening and snaps shut just as it should.NZSpokes wrote:I do both. Quick turn and single cable.sirch345 wrote:I'm guessing none of you guys have ever had a throttle stick open, it's not a nice experience. Personally I'd go with a quick-action throttle instead,
everything went well no dramas no snapped fasteners, or lost parts and nothing left over (well apart from the return cable
![Big Grin :biggrin](./images/smilies/biggrin.gif)
Storm is now gone
Storm is now gone
Damm...Here's that Cyber £ I owe you then...budd wrote:HRC throttle tube fitted, return cable deleted, everything lubed and feels nice, smooth opening and snaps shut just as it should.NZSpokes wrote:I do both. Quick turn and single cable.sirch345 wrote:I'm guessing none of you guys have ever had a throttle stick open, it's not a nice experience. Personally I'd go with a quick-action throttle instead,
Chris.![]()
everything went well no dramas no snapped fasteners, or lost parts and nothing left over (well apart from the return cable) as Mac said nice simple job, now I just need to take it for a spin
![Mad :x](./images/smilies/icon_mad.gif)
You've got the wrong end of the stick Carlcybercarl wrote:Mid corner'm guessing none of you guys have ever had a throttle stick open![]()
One can hit the kill switch but that's not as instinctive as closing the throttle and there will be millisecs as brain/hand decides to move from a to b and hit the kill switch.
The chances of a throttle sticking open are I would say rare, but in my experience if they are going to stick it happens at full chat, or very close to it. In a situation like that where you could need to shut the throttle off immediately, you do that with instinct, you may not have time to think about an alternative reaction.
As I have said in all my posts in this thread, that's only my personal opinion gained from my own experiences. You must do what you feel happy with regarding throttle modifications,
Lust, but don't dribble, unworthy ones.
Cheaper than you think, and used by MotoGP, WSB and BSB teams.
There must be something going for them.....
http://www.mrsltd.co.uk/DominoThrottleRange.htm
