Hi
Does the bigger fuel tank go straight on as a replacement or are there modifications to do..?
Fuel tank
Re: Fuel tank
Yes - Have a search as it's a subject that often crops up.
Re: Fuel tank
No modifications to the tank itself off at all. It will fit straight on, but you will need other bits to get it working.
- Redthunder
Re: Fuel tank
Fuel sender and cap from your 16l and need a fuel tap: either original for 19l if can find one (£180 new!) or gravity fed such as varadero (no tap). If use original also need take off which screws on bottom of 19l.
