Can`t believe what a bit of time and patience can achieve. I though it was beyond repair but after attacking it with a dremmel and giving it a lick of hammerite smooth it looks like new
Who`d have thunked it
- agentpineapple
Re: Who`d have thunked it
looks like you did a top job, and you have the satisfaction of doing it yourself, i'd even consider throwing a load of lacquer on it for extra protection....
good work you must be chuffed.
Cheers chaps. Yeh well chuffed. Trying to get 14yrs of chain lube off the sprocket carrier now . Dam this stuff is stuck like poop to a blanket
Paul
Good job Did you note there is an arrow on the side of one of the plates so you put it on the bike with the arrow pointing forward. I hope you haven't covered that up in a thick coat of Hammerite.
pstormer wrote:Cheers chaps. Yeh well chuffed. Trying to get 14yrs of chain lube off the sprocket carrier now . Dam this stuff is stuck like poop to a blanket
Spray loads of WD-40 on it & let it soak over night, even better if you can put it in a pot or something & cover it in engine cleaner or even petrol & soak over night.
Well done, you would hardly recognise it now
Shows what can be done with a bit of time or patience. That looks great
