hi men i'm after some ideas for my front indicators
what would you suggest
thanks
front indicators
front indicators
Re: front indicators
100's of types to choose from take your pick what ever you like TBH.macdee wrote:hi men i'm after some ideas for my front indicators
thanks
I use these...
http://www.jsaccessories.co.uk/accessor ... -shem.html
Long ones on the front short on the back but you will need a new flasher relay as well.
You cant mix front & rear with LED's its both ends or nothing...
- Saintsman27
I thought about swapping mine from the standard fitted and whilst digitals
look good and modern and shall I say " Flashy "....... but I decided to stop with the originals
I quite like the standard big bold and visible VTR indicators that Honda designed and fitted and
can be easily seen at speed by other road users.
Get some flush fit clear lens ones had them on mine. They looked good
Or you could get some little flags that pop out and up when you push the button. A bit like the old Morris travellers.
- cliveyandrews
- Contact:
I have mixed incandescent (OEM) indicators front & LED rear with no issues (solid state relay though)
Audi, Vide, Tace
Audi, Vide, Tace
I have these along with an electronic flash relay which makes sure that the indicators blink at the correct rate.MacV2 wrote:100's of types to choose from take your pick what ever you like TBH.macdee wrote:hi men i'm after some ideas for my front indicators
thanks
I use these...
