Anyone got a lightly damaged one?
I let my last good one go a while back, and need one for the rolling chassis I plan to use to make custom exhausts on- it's sort of a jig, if you get the picture, fitted with empty engine cases etc, no point in using a good mounting bracket/casting as they're needed to keep bikes on the road.
As I don't use the link pipe mounting bracket the location point for that doesn't matter much, so if you've replaced a slightly bent one with a good one, or have one with a crack in, please let me know.
Beer tokens await
slightly bent RH footrest casting wanted
Moderator: VTRDark
- agentpineapple
Re: slightly bent RH footrest casting wanted
i'll have a look when I get back in a couple of weeks mate....
Thanks, but as you're away I've already broken in and rifled through your stock shed, and you haven't got a RH one, only the left one.
