Exhaust studs
Moderator: VTRDark
Exhaust studs
Snapped one of the buggers on the front today. Rears were fine, the nuts came off leaving the stud in the head. I'm after a couple. To be honest, if someone could point me in the right direction of new ones ( pref stainless ) that would be most appreciated.
Only went to take the buggers off to clean & coppaslip them up, bit of prevention better than cure. Had no other reason to touch them, now the whole bloody system's off. Suppose I'll have to clean it now !!
Re: Exhaust studs
Is this considered a mod.
Sorry Lee couldn't resist. Basterd studs, I know how you feel. What are you plans for getting the snapped stud out?
Re: Exhaust studs
Would anyone here have a time-set kit with 8mm inserts I could borrow once I drill my stud out. I prefer them to helicoils but they are darn pricey as you have to buy full kits not just the size you want?
Re: Exhaust studs
I just had to look that one up as I have never heard of them. Your not wrong about expensive.
First link I found.
http://www.amazon.com/TIME-SERT-Metric- ... B001JK44LG
It's the drilling out of the old stud which is the real problem. If drilled out properly (square on and right size) it can then just be re tapped I would have thought.
First link I found.
Re: Exhaust studs
Agreed on the drilling bit, so I have acquired a set of stainless steel cobalt drill bits & a center drill. Incidentally is that the correct thread size for the stud on tha amazon link??cybercarl wrote:I just had to look that one up as I have never heard of them. Your not wrong about expensive.
First link I found.![]()
Re: Exhaust studs
That''s the route I first took.Agreed on the drilling bit, so I have acquired a set of stainless steel cobalt drill bits & a center drill.
![EEK! :eek2](./images/smilies/eek.gif)
See http://www.vtr1000.org/phpBB3/viewtopic ... 30#p312102
Don't know mate just searched your quoteIncidentally is that the correct thread size for the stud on tha amazon link??
and that came up. I presume your referring to the thread pitch. Best to measure the new studs. They seem to vary from seller to seller on eBay. In fact I would buy genuine Honda studs next time. Your maximum hole should be slightly smaller allowing for tapping. This is presuming that you can drill through the old studtime-set kit with 8mm inserts
![Sad :(](./images/smilies/icon_sad.gif)
![Thumbdown :thumbdown:](./images/smilies/icon_thumbdown.gif)
Re: Exhaust studs
You have the same problem as Lloydie!darkember wrote:Would anyone here have inserts I could borrow once I drill my stud out. I prefer them to coils but they are darn pricey as you have to buy just the size you want?
Re: Exhaust studs
I ended up using a helicoil alternative....Clarke from machine mart, £17.99 for the kit for m8 with 25 inserts. I did manage to drill the stud but for the life of me couldnt remove the last millimetre of thread from the head. Gave up trying and bought the kit, took me 20 minutes and done. Obviously would rather it was as new, but these things happen, and the repair seems to be a good option.
Re: Exhaust studs
Did you drill with the head in situe or removed??leevtr wrote:I ended up using a helicoil alternative....Clarke from machine mart, £17.99 for the kit for m8 with 25 inserts. I did manage to drill the stud but for the life of me couldnt remove the last millimetre of thread from the head. Gave up trying and bought the kit, took me 20 minutes and done. Obviously would rather it was as new, but these things happen, and the repair seems to be a good option.
Re: Exhaust studs
darkember wrote:Did you drill with the head in situe or removed??leevtr wrote:I ended up using a helicoil alternative....Clarke from machine mart, £17.99 for the kit for m8 with 25 inserts. I did manage to drill the stud but for the life of me couldnt remove the last millimetre of thread from the head. Gave up trying and bought the kit, took me 20 minutes and done. Obviously would rather it was as new, but these things happen, and the repair seems to be a good option.
PM sent !!
