Chain Lube, Chain Wax, or WD40?
Whilst the Hound is still some way off turning it's wheels in anger again, what do people recommend? I used to use an expensive chain lube on the FZRs/SZR but in recent times Chain Wax seems to the thing. I've even heard you can use WD-40/GT85, which doesn't fling off or leave much residue for grit and dirt to cling to?
Re: Chain Lube, Chain Wax, or WD40?
Dont use WD-40 it will clean off all the lube & evaporate leaving you with no lube...!Mav617 wrote:Whilst the Hound is still some way off turning it's wheels in anger again, what do people recommend? I used to use an expensive chain lube on the FZRs/SZR but in recent times Chain Wax seems to the thing. I've even heard you can use WD-40/GT85, which doesn't fling off or leave much residue for grit and dirt to cling to?
Wax is OK, Scotoiler is better.
scottoiler..
Chain wax, or dry lube, It works for me
Like what you do
Do what you like He who wonders isn't always lost
Wax for me
Go in dry for me! Did I say that out loud . Wax for me
Old engine oil for me
- Saintsman27
My small Honda riders info book says... SAE 80/90 Gear oil on the chain
I fitted a "loober" small cylinder which drips a given amount of oil
on the chain ... a less sophisticated Scott oiler but a very effective
oiling device.... for less than £20 it gets 10w/40w mineral oil
and the chains fine..
Clean the chain with kerosene, then apply heavy differential gear oil and seal in with a good wax. Lasts for 600 mileslloydie wrote:Old engine oil for me
I do clean it monthly and oil it every week (when in use)
- fireballxl5
My fav is Wurth High Performance Dry Chain Lub, very little fling off hence no mess.
IMO if you commute daily a scottoiler is the answer.
45 uses for WD40
http://www.bloggingwv.com/45-uses-for-wd-40/
Over the years I've used most oils, waxes (cook in the tray in the oven ), greases & many of the bikes I've had have been fitted with Scottoilers.
Now I just use WD40. I apply it by spinning the rear wheel when it's on the centre stand after each ride
I do agree it sounds terrible, but my theory is that with todays modern O or X ring chains there is no way that any of the lubes mentioned above will penetrate the sealing rings & lube the pins.
They are lubed with white grease at manufacture & if they did leak due to the unbelievable centrifugal forces that chains are put through there would be white grease everywhere.
So I recon there is no way in hell that spraying or painting any lube on a chain is going anywhere apart from on top of the links & all over the bike.
Bel-Ray 6 in 1, similar to WD40. I just apply it and wipe the excess off, holds 200-400 miles. Never clean the chain, as all the debris come out with aplication and wipeoff the grease. It just take me few minutes to maintain the chain.
I run 520 chain with alu rear sprocket and dont see any issue, last one was replaced after 12.000 miles.
