k & n filter
k & n filter
Hi, i have just got hold of a second hand k & n filter and i'm not sure if i,ve been given the full kit. Should i have got some little blanking covers to go over the small inlets inside the airbox as i didnt get any and i have seen pics with them blankd off. if i am missing them could i just blank them off with tape ??????
- Stormtrooper
yes you should of got that. Now i've been told that you can trace that hose to each cyclinder. it should lead to a read valve on top of each cylinder. They told me that you can remove all that plumbing and stick a marble or a ball bearing in there to block it of. Something not to small to fall inside. this is supposed to make all the poping go away. that stuff is there for emmisions
Adeptus Mechanicus
