Sp1 front wheel
Moderator: VTRDark
- thumperslaw
Sp1 front wheel
Long shot I know!
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
- agentpineapple
Re: Sp1 front wheel
good luck with that one buddy, finding a good condition cheap sp1 front wheel is like finding the preverbial rocking horse doo doo.
Re: Sp1 front wheel
How about a sp2 wheel
http://bit.ly/1b2srW3
Re: Sp1 front wheel
Yeah they are rare and also pricey...... I can check with my sources if you really decide you want one but again you would be hunting special bearings to get it to mate up to a 929 axle.
Re: Sp1 front wheel
929/954 front wheels are 3-spoke, so match stock VTR rear also.... I think a frnt wheel from a CBR1000RR would also work (not sure about axle size, but the 929/954 rotors should bolt right up)
Re: Sp1 front wheel
Sounds like he has a hankering for a 6 spoke front wheel though......
- thumperslaw
Re: Sp1 front wheel
Going to have it!lloydie wrote:How about a sp2 wheel
I'll bend over now
K100 "flying brick"
K100 "flying brick"
Re: Sp1 front wheel
Here is one for you, if you want to bend over even farther......
http://www.ebay.com/itm/HONDA-RC51-RVT1 ... ed&vxp=mtr
Though the advantage of running a 5 spoke SP2 wheel, and why I run one with my 6 spoke rear, is that it is 1.5 lbs lighter than an SP1 wheel.
Yes I did manage to round up one of each when I did my swap..... though I did get rid of the extra wheel a while ago.
Re: Sp1 front wheel
Just don't bend over too far or we will have to ban you.
Re: Sp1 front wheel
alright, who dropped the soap? Go on, fess up
Re: Sp1 front wheel
One last thing: once you have those massive 330mm rotors on, few, if any, will/would be able to notice you are running a 5-spoke (SP-2) in place of a 6-spoke.... food for thought.......
BTW, assuming it's straight, that wheel linked by Lloydie could be quite a deal... you can likely get most of the money back just from selling off the rotors..... more food for thought...
- thumperslaw
Re: Sp1 front wheel
Don't care if it's five spoke or six spoke just need some thingmik_str wrote:One last thing: once you have those massive 330mm rotors on, few, if any, will/would be able to notice you are running a 5-spoke (SP-2) in place of a 6-spoke.... food for thought.......
plan is to sell the fresh powered coated vfr400 wheel for a sp-1 or 2 wheel
K100 "flying brick"
K100 "flying brick"
Re: Sp1 front wheel
[quote="thumperslaw]Don't care if it's five spoke or six spoke just need some thing
[/quote]
well, in that case, you could carve one out of granite or hardwood.......
[/quote]
- thumperslaw
Re: Sp1 front wheel
well, in that case, you could carve one out of granite or hardwood....... [/quote][/quote][/quote]mik_str wrote:[quote="thumperslaw]Don't care if it's five spoke or six spoke just need some thing
Make one out of billet
K100 "flying brick"
K100 "flying brick"
- thumperslaw
Re: Sp1 front wheel
Still after one.....
K100 "flying brick"
K100 "flying brick"
