black swing arm
black swing arm
had a day off today to get the swing arm on thought i would take a day at it because pound to a pinch of sh1t sumut will go wrong! as it goes it went ok one of the lower linkage bolts was stuck solid and took 4ton on the press + heat. I put greese nipples in the linkages so now i can keep on top of it. I was after a better looking chain guard and when i took the standard one off i found that the pyramid hugger incorporates a chain guard result! seems the old one was just bolted over top
If sh1t were money you would be worth a fortune
Re: black swing arm
Swing arm looks good
where did you get the carbon straps for the exhaust? I like them
also your rear disk looks worn
Re: black swing arm
Looking good Pete. My hugger/ chain guard is a Pyramid and the original chain guard fits over the top completely , don't know if you could?
Theres A Hare in The Turnips.
Re: black swing arm
Nice looking job mate.
Re: black swing arm
I think the Pyramid is designed with putting the original chain guard over the top in mind. Looking good Pete and I'm liking the little bits of carbon in places. You just need some carbon hangers now.
- agentpineapple
Re: black swing arm
Carl is correct, the pyramid hugger is designed for the original to fit over the top, I don't think it covers enough of the chain otherwise. On its own the rear end could get a bit mucky from chain lube. I know where he got the c/f straps from....
Re: black swing arm
bigspanishmarty wrote: I know where he got the c/f straps from....
OK where did you get the CF starps from Marty????
Re: black swing arm
Nice job Pete
Re: black swing arm
......and I know where you got them from. Git!!!!bigspanishmarty wrote:Carl is correct, the pyramid hugger is designed for the original to fit over the top, I don't think it covers enough of the chain otherwise. On its own the rear end could get a bit mucky from chain lube. I know where he got the c/f straps from....
Re: black swing arm
And I know where you got them from.
Al just keep an eye out on ebay for akrapovic straps. Just make sure they are the right size and shape.
Or http://www.busters-accessories.co.uk/pr ... Ref=561387
- agentpineapple
Re: black swing arm
ME..................AMCQ46 wrote:bigspanishmarty wrote: I know where he got the c/f straps from....
and yes before that kev had them, but in fairness he did snipe them from me in the first place.....
now i can't remember if i've paid kev for them yet..........
Last edited by agentpineapple on Mon Apr 22, 2013 5:55 pm, edited 1 time in total.
Re: black swing arm
i got them off marty dont know where he got them from? the disc is worn but as back brakes are as much use pushing smoke up your butt with a knitting neddle im botherd untill mot timeAMCQ46 wrote:Swing arm looks good
Re: black swing arm
I use the back brake a lot, especially on corners or just gradually slowing down to lights. Saves wear and tear on the fronts and it's cheaper to replace one set of pads than two.
Re: black swing arm
you are right mate since putting new pads in i have tryed to use it more as a gradual brake into cornerscybercarl wrote:I use the back brake a lot, especially on corners or just gradually slowing down to lights. Saves wear and tear on the fronts and it's cheaper to replace one set of pads than two.
Re: black swing arm
No you bleeding well haven't, hence the Git comment!!bigspanishmarty wrote:ME..................AMCQ46 wrote:bigspanishmarty wrote: I know where he got the c/f straps from....
