stuck right baffle
callam_nffc
stuck right baffle
Post by callam_nffc »
Dear right baffle,
Please will you finally give up and come out? Haha
The left is all sorted, just got the right one to the point where I can move it back and forth easily, but it won't actually pull out, as if its catching on something
Any tips?
CBR125 - XJ600S DIVERSION - YZF600R THUNDERCAT - VTR1000 FIRESTORM
I still crave a supermoto...
bluestoesonnose
Re: stuck right baffle
Post by bluestoesonnose »
Pull harder
Bigger hammer, longer drill bit, more brute force.
Or just buy cans.
callam_nffc wrote:Dear right baffle,
Any tips?
Wack it more
Ride it and the vibration will get it out
edds11
Post by edds11 »
mine where the same , keep going, but wear gloves, it will come loose and you WILL cut your hand...crack on buddy
Miztaziggy
Post by Miztaziggy »
tony.mon wrote:Bigger hammer
Solves so many problems :D
bigtwinthing
Post by bigtwinthing »
pull it harder and faster, if that doesnt work have a go at the exhaust :biggrin
Walk away from it have a cuppa & a fag or a beer & fag.
Go back clamp it with a pair of mole grips on the spout then just give it loads of in & out as fast as poss, it will weaken the weld & eventually snap.
Remember in, out, in , out, snap it all out. :thumbup:
callam_nffc
I've knocked it on the head for the night as it was getting dark, will have another swing/kick/stab at it in the morning lol
I think the pull push as quick as possible method needs to be employed, how is hitting it with a hammer going to work? Its already completely free, can even revolve it 360degrees, just won't come out
Like mac said. Mole grips and pull as fast as you can from fully in
You need to make the back hole bigger
callam_nffc
Yeah but whacking it won't make it bigger will it? Or am I just being thick :confused
I could do with a 8 inch or more narrow chisel to bash away at it with lol
callam_nffc wrote:Yeah but whacking it won't make it bigger will it? Or am I just being thick :confused
That's what I did :-)
Hitting it with a hammer will send shock waves to it and weaken it some more :!:
You pay want to put a bit a twisting action into the in and out push pulls. :thumbup:
