" Keep the chit chat out and keep it strictly to dyno charts and corresponding setup for the chart."
Cheers for the quote Carl
section rules
section rules
Everything good is bad
Everything bad is good
Re: section rules
Might be an ideal Jazz if people filled this in with the dyno chart, then you can see how its produced
AIRBOX
MAIN -
SNORKEL -
LID -
VELOCITY STACKS -
FILTER -
EXHAUST
PIPES -
CANS -
STYLE -
FRONT CARB
MAIN AIR JET DRILLED -
MAIN -
EMULSION TUBE -
NEEDLES -
SLIDES -
SPRINGS -
PILOT -
A/F SCREW -
REAR CARB
MAIN -
EMULSION TUBE -
NEEDLES -
SLIDES -
SPRINGS -
PILOT -
A/F SCREW -
OTHER VARIABLES
TPS -
IGNITION ADVANCER -
COILS -
GEARING -
CLUTCH -
FLYWHEEL -
PISTONS -
CAMS -
OIL COOLER -
ENGINE OIL -
HEAD WORK -
OTHER -
DYNO SHEET -
AIRBOX
MAIN -
SNORKEL -
LID -
VELOCITY STACKS -
FILTER -
EXHAUST
PIPES -
CANS -
STYLE -
FRONT CARB
MAIN -
EMULSION TUBE -
NEEDLES -
SLIDES -
SPRINGS -
PILOT -
A/F SCREW -
REAR CARB
MAIN -
EMULSION TUBE -
NEEDLES -
SLIDES -
SPRINGS -
PILOT -
A/F SCREW -
OTHER VARIABLES
TPS -
IGNITION ADVANCER -
COILS -
GEARING -
CLUTCH -
FLYWHEEL -
PISTONS -
CAMS -
OIL COOLER -
ENGINE OIL -
HEAD WORK -
OTHER -
DYNO SHEET -
