section rules
Just post charts and set up details.
Jazzscot
section rules
Post by Jazzscot »
" Keep the chit chat out and keep it strictly to dyno charts and corresponding setup for the chart."
Cheers for the quote Carl
Everything good is bad
Everything bad is good
seb421
Re: section rules
Post by seb421 »
Might be an ideal Jazz if people filled this in with the dyno chart, then you can see how its produced :idea:
AIRBOX
MAIN -
SNORKEL -
LID -
VELOCITY STACKS -
FILTER -
EXHAUST
PIPES -
CANS -
STYLE -
FRONT CARB
MAIN AIR JET DRILLED -
MAIN -
EMULSION TUBE -
NEEDLES -
SLIDES -
SPRINGS -
PILOT -
A/F SCREW -
REAR CARB
MAIN -
EMULSION TUBE -
NEEDLES -
SLIDES -
SPRINGS -
PILOT -
A/F SCREW -
OTHER VARIABLES
TPS -
IGNITION ADVANCER -
COILS -
GEARING -
CLUTCH -
FLYWHEEL -
PISTONS -
CAMS -
OIL COOLER -
ENGINE OIL -
HEAD WORK -
OTHER -
DYNO SHEET -
