Powder Coat Sub Frame
carmanbikes
Post by carmanbikes »
Hi All,Thinking of powder coating the rear sub frame has anyone ever had any problems with bad earths or any thing else to look out for,Cheers
malone
Re: Powder Coat Sub Frame
Post by malone »
I'll tell you in about a week :D
I delivered a rusty sub frame.....sandblasted and then powder coated. I expect it to be as new but I will let you know!
'99 Firestorm - lots of fun!!
http://www.batterifabrikken.dk
Done mine :-)
You need to remove some of the coating from the sub frame where it bolts to the main frame .
And on the other earthing points .
carmanbikes
lloydiecbr wrote:Done mine :-)
Hi Did you have all the frame done and remove bits or mask the bits off before powder coating
making would be best . show the powder coater where you dont want done :thumbup:
my main frame is painted and the sub frames are powder coated .
you need good earths on the storm
Re masking, just put a nut and bolt through with a large washer on the side where you don't want coating. Better than tape, as it won't come off when it's being blasted.
Geordie
Post by Geordie »
yip done this .. week later had some crazy stuff going on on the bike .. bad earth, so I ran a new piece of earth cable from the negative to the earth bolt near the regulator, all sorted .. I have done about 3000 miles on the bike since and the powder coating is failing underneath and rust bubbling through .. pish job .. make sure its well shot blasted first ..
you could always use tony's patented garden hose mod on the center bar that gets the worst of the corrosion...... :wink:
