Exhaust Paint
carmanbikes
Exhaust Paint
Post by carmanbikes »
Hi,Any one know or used a good paint on the exhaust as mine looks terrible at the front,Thanks
Flatline
Re: Exhaust Paint
Post by Flatline »
Try frost.co.uk they do that sort of thing
Re: Exhaust Paint
Frost paints http://www.frost.co.uk/automotive-paint.html Just make sure it's a high temperature resisting paint like VHT. You will have to take the pipes off to do a proper job. So be warned, the exhaust studs may snap on the cylinder head. So be prepared to replace them. :eek2
One of the guys had good results with this stuff recently.
http://www.ebay.co.uk/itm/281016020764? ... 1423.l2649
scrowe
Re: Exhaust Paint
Post by scrowe »
TBH even the halfords VHT exhaust spray paint looks good. exhaust paint on the headers will always end up looking tired regardless over time so it ends up being a regular touch up. you can spend twice as much on paint but not get twice the finish.
is there no way the down pipes can be cleaned up with a coarse mop on a drill.
Re: Exhaust Paint
scrowe wrote:TBH even the halfords VHT exhaust spray paint looks good. exhaust paint on the headers will always end up looking tired regardless over time so it ends up being a regular touch up. you can spend twice as much on paint but not get twice the finish.
Yes.
It helps if you can be bothered to take them off first.
I gave mine a scrub up with a wire brush cup on a drill, in situ I might add as I couldn't be bothered to take them off, certainly improved them.
IIRC Carl took the headers off & did his by hand. He'll be along shortly to..
a/ warn of aching hands & arms & blisters.
b/snapped exhaust studs.
c/increase his post count.
Re: Exhaust Paint
http://www.vtr1000.org/phpBB3/viewtopic ... 55#p217436
Yep hard work, a snapped exhaust stud and another post count. :lol:
thumperslaw
Re: Exhaust Paint
Post by thumperslaw »
ceramic exhaust coating works well
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
