thumperslaw
Posts: 1209 Joined: Thu Nov 24, 2011 7:14 pm
Post
by thumperslaw » Thu Jan 10, 2013 10:27 am
Fitted them Wednesday and went for a long blast. Time to think about them as they are higher then standard
Still in two mines if I like them :/
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Steve6088
Posts: 833 Joined: Tue Jun 21, 2011 4:17 pm
Post
by Steve6088 » Thu Jan 10, 2013 11:20 am
Maybe you could mount them below the top yoke to make them lower, if there is space?
thumperslaw
Post
by thumperslaw » Thu Jan 10, 2013 12:21 pm
Thinking about it but would have some steering props?
K100 "flying brick"
Posts: 16593 Joined: Mon May 11, 2009 4:54 pm
Post
by AMCQ46 » Thu Jan 10, 2013 12:26 pm
they look good compared to standard so that fulfills 1 of your requirements
they look to be higher where they mount to the forks, but have a steeper angle downwards .... so do you think your hands are back in the same place or still higher than normal?
Phimosis
Posts: 291 Joined: Mon Dec 05, 2011 3:43 am
Post
by Phimosis » Thu Jan 10, 2013 12:29 pm
Thats a fair bit higher isnt it, wont be surprised if you get back ache...let me know if you do as im thinking of raising mine a bit...
She told me she was 16.
thumperslaw
Post
by thumperslaw » Thu Jan 10, 2013 1:27 pm
Thinking of selling them and buying some others to see what they would be like
K100 "flying brick"
Posts: 20010 Joined: Sun Mar 18, 2012 9:24 pm
Post
by VTRDark » Thu Jan 10, 2013 1:36 pm
I ended up putting later model Storm bars on and it's surprising how much of a difference the small 5 degree lift makes. When put side by side with the old bars, I would say they are about 1/2 inch higher at bar ends.
thumperslaw
Post
by thumperslaw » Thu Jan 10, 2013 2:18 pm
Want to go lower now
K100 "flying brick"
Posts: 7895 Joined: Sat Feb 11, 2006 2:43 pm
Post
by Wicky » Thu Jan 10, 2013 2:59 pm
AS Steve6088 said, try mounting them below the top yoke.
thumperslaw
Post
by thumperslaw » Thu Jan 10, 2013 3:34 pm
Just brought other clamps now so I can now see them both on the bike.
K100 "flying brick"
bigtwinthing
Posts: 5577 Joined: Mon Dec 17, 2012 7:52 pm
Post
by bigtwinthing » Fri Jan 11, 2013 9:26 pm
did you have to alter anything, hoses,cables etc?
thumperslaw
Post
by thumperslaw » Fri Jan 11, 2013 10:06 pm
bigtwinthing wrote: did you have to alter anything, hoses,cables etc?
Luck for me no!
K100 "flying brick"
thumperslaw
Post
by thumperslaw » Mon Jan 21, 2013 10:18 am
Got second pair of clamps
Now they are lower then the other ones I brought
K100 "flying brick"
Posts: 20923 Joined: Mon Jan 17, 2011 11:16 pm
Post
by lloydie » Mon Jan 21, 2013 10:37 am
Should make it easier to get your chin on the tank !
thumperslaw
Post
by thumperslaw » Mon Jan 21, 2013 10:40 am
lloydiecbr wrote: Should make it easier to get your chin on the tank !
Slip stream is in for 2013!
The other clamps where to high for me
K100 "flying brick"
