Fork brace
Fork brace
Been given a telefix fork brace by my dad, it used to be fitted to his 97 cbr1000.
Does anybody know if it'll fit the storm ?
I'd go and try it right now but its bloody heaving down as usual !
Re: Fork brace
Managed to get out between rain showers and can confirm that it does fit :-)
Re: Fork brace
I take it that is on the standard 41mm forks. It should make a difference to stability. Get some pics up when you get a chance, be nice to see how it looks.
Re: Fork brace
Yes that's on original 41mm forks.
I have a pic but its come out crap and makes the bike look pink !
![Image](http://img.tapatalk.com/d/12/10/02/5e4yduzy.jpg)
Re: Fork brace
Hope your sag is set right as it might touch the bottom yoke if not !!!
Re: Fork brace
Good pointHope your sag is set right as it might touch the bottom yoke if not !!!
Looks OK, not as blingy as a coerce but it serves a purpose and it was free so all good.
Re: Fork brace
lloydie, I think the clearance will be OK, as the normal plastic shields sit taller than that.
carl, the slit is to allow the 2 sides to be adjustable for subtle tolerance variations beyween fork legs
Re: Fork brace
not too sure if it's an issue with the VTR but I'd be very concerned with fork stiction using fork braces. Easy to check. Lift up on front end and let it go down again. Forks should return to same position smoothly. Push down and pump several times, should return to same position smoothly. If you have a dial gauge you can check to see if the forks are same width apart top and bottom. Measure using dial gauge from bottom yolk to above the sliders. Should be the same. You will need the sliders off to check for parallel. With sliders off, use a plate of glass on the fork stanchions to check, if the glass rocks corner to corner the forks are out of alignment. The bike can be dangerous if fork stiction is present, it will feel like a jack hammer and will be troublesome in curves. Be careful when installing fork braces. Everything needs to be in perfect alignment.
Re: Fork brace
if there was a problem with fork braces, you wouldn't be able to buy them in the states, because of their lunatic compensation culture. you can. they're fine.twist wrote:not too sure if it's an issue with the VTR but I'd be very concerned with fork stiction using fork braces.
a dial gauge is used for checking run out,twist wrote: Easy to check. Lift up on front end and let it go down again. Forks should return to same position smoothly. Push down and pump several times, should return to same position smoothly. If you have a dial gauge you can check to see if the forks are same width apart top and bottom. Measure using dial gauge from bottom yolk to above the sliders. Should be the same.
![Image](http://i59.photobucket.com/albums/g303/flumpkins/Dial-gauge-with-magnetic-stand.jpg)
if you're giving people advice, please use the correct terminology, ta.
is it just me who thinks this is all getting a bit too anal??????twist wrote: You will need the sliders off to check for parallel. With sliders off, use a plate of glass on the fork stanchions to check, if the glass rocks corner to corner the forks are out of alignment.
you wanna check the tolerances on the stuff coming out of japan.......twist wrote:The bike can be dangerous if fork stiction is present, it will feel like a jack hammer and will be troublesome in curves. Be careful when installing fork braces. Everything needs to be in perfect alignment.
When subjected to an electrical voltage of at least 50 volts, a cat's tail always points toward the north.
Re: Fork brace
I'd have thought it should be fine, unless when installing it the clamp is clearly pulling the forks out of their existing position.
If so you could try supporting the bike and loosening all of the clamp bolts when installing it, then rotating each stanchion to see if there is any resistance.
But I'd be just fitting them, riding it, and seeing how it felt, tbh, if they seem to fit ok.
Re: Fork brace
Managed a quick run out before the rain again, can't feel much of a difference although on bumpy corners it feels a bit more stable.
Can't say I'd be happy if I'd paid full price for it but as a freebie it's a winner.
The slit you can see is down to the central brace being in 2 halfs, bolted together at the back.
http://www.mandp.co.uk/netalogue/conten ... FBTFBK.jpg
Re: Fork brace
Then it's doing what it's meant to.templ8 wrote:h on bumpy corners it feels a bit more stable.
Result!
Re: Fork brace
rob he's Californian, they fill they vehicles with gas and their crisps are chips.please use the correct terminology, ta.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Thanks for the link that makes total sense now.The slit you can see is down to the central brace being in 2 halfs, bolted together at the back.
