Benny's specks are better as they show the maximum to can remove from it .
Then make your own choice on how much you want to remove .
But rob's is ready to go and its a lot less fouling around :-)
i have a lightened flywheel on my bike and theres no problem with tickover or uneven idling, what you do get is an engine that spins up the revs alot quicker than standard, some people like it some don't, if you could blag a ride on someones bike whose had it done, you could decide weither its to your liking. personally i think there isn't much in it, it probably makes the big a little bit harder to ride smoothly but the trade off is harder and faster acceleration. you pays your money and takes your chances.....
bigspanishmarty wrote:i have a lightened flywheel on my bike and theres no problem with tickover or uneven idling, what you do get is an engine that spins up the revs alot quicker than standard, some people like it some don't, if you could blag a ride on someones bike whose had it done, you could decide weither its to your liking. personally i think there isn't much in it, it probably makes the big a little bit harder to ride smoothly but the trade off is harder and faster acceleration. you pays your money and takes your chances.....
you will notice it if your bike was at full power .
It makes a big change to the way the engine spins up .
It revs up faster and so you go faster :-)
Just done a deal and I've bought his lightened flywheel
Fitting looks easy enough, famous last words...... Is it worth getting a new gasket for the cover or should the old one come off intact? If it does fall to bits is a bit of Hylomar gasket sealer ok? It's not like anything will leak out
'02 VTR1000-FY Yellow.
Rob wrote:is a bit of Hylomar gasket sealer ok? It's not like anything will leak out
there is oil under there. get a new gasket.
you will also need a m22x1.5mm bolt to get the flywheel off.
search the forums you will find a few alternatives - there is no other way to remove the flywheel!!!!!!!
I've got a big hammer
Ok, thanks, will do. 22x1.5mm - why do honda always use strange bolt sizes?
