The last few days my 'Storm's clutch is making a light clunk sound while I release it. It's especially noticable at pull-away or at slow speed use. Also, this morning at pull-away after a hard stop, I had to try two or three times to pull away as the clutch just 'grabbed' but also with a squeeling type noise.
Any answer will be appreciated.
Is my clutch failing???
- smokin joes
- Contact:
Check in order of cheapness to repair...
1) Fluid,
2) Is the "other end" fastened on securely, ie the piston bit that pushes the rod ?
3) Thrust bearing shaft nice and slippy ??
4) thrust bearing ok ?
I had a similar thing on mine, it was "grabby" felt like I was letting the clutch in and out two or three times before it would grab properly,
FIX.... £8.00 worth of EBC clutch springs and 20 mins to swap em,
also theyare 20% stronger than stock.
hope this helps,
Geoff M
1) Fluid,
hope this helps,
Geoff M
Sex is like air. It only becomes really important when you aren't getting any.
