moriwaki carbon belly pan
Can anyone help, just got hold of a belly pan off ebay and I am having a complete nightmare trying to fit it due to lack of instructions, front brackets seem ok although front rh is a little off line but there seems nowhere for the rear brackets to visably fit the seller said it was a pain to fit, but I am just baffled can anyone help?
- Stormtrooper
- Stormtrooper
- EggShellBlond
Hi & welcome cashy
I'll try and describe fitting mine , and hopefully that'll help
There are 4 brackets;
2 double mounting points
2 single mounting points
Nearside left and Offside front are double's and are therefore constants ( ie no adjistability
fit these first , finger tight , and then fit the other 2 LOOSELY
Offer up the bellypan , and loosley fix the hex head bolts
Then adjust the single's into place , when you're happy with the adjustments tighten up enough so they don't move
Remove Bellypan and tighten all mountings to the correct torque settings ( from Haynes Manual , got one in the car if you need them )
I found it best to use Threadlock , as they are subject to some ( serious )vibrations
I Hope this makes sense , and is helpful
Stu
Stu
If a job's worth doing..........It's worth paying someone to do it properly
