can i ?
warfox
can i ?
Post by warfox »
can i fit a 190 tyre ?
as i need a new one it looks like theres just enough room but want to c if any one else has done it
also want to add a hugger so any help on the best one would be good :lol:
delmeekc
Post by delmeekc »
yep and yep I can do you a hugger in CF.
PM us.
Del.
curly
Post by curly »
Hi,
Would it improve the handling? Or is it just because bigger tyres look better? :?:
Curly
delmeekc
Post by delmeekc »
well, with the right 190 tyre then you will get more rubber on the road when leant over i guess.
Del.
warfox
Post by warfox »
to b honest im not a fast rider round beds in comparison to some but im getting faster still get the odd square corner :oops:
and the looks of a bigger tyre is an added bonus :wink:
will pm u now DEL :)
essexbloke
Post by essexbloke »
i ran a 190 not that long ago, didnt actually feel any different to be honest. Didnt even look any bigger either.....
Ps, i've got a hugger and it fitted fine.....
warfox
Post by warfox »
tnx all
got bike booked in for a tyre and in touch with Del for hugger ....sorted :)
robin1000
Post by robin1000 »
Along the same lines, how difficult is it to fit 'Blade forks and from what year model would I need them??
Bikes and scorned women don't mix!
Stormin Ben
Post by Stormin Ben »
robin1000 wrote:Along the same lines, how difficult is it to fit 'Blade forks and from what year model would I need them??
Up to '98 ones drop virtually straight in. You use the blade yokes and wheel spacers and the storm wheel and disks and head bearings fit straight in.
However, the blade forks are shorter and fit flush with the top yoke so you'll need some riser clip-ons to fit under the yoke.
Ben
PS I didn't actually do mine from scratch, I bought the front end of someone else and fitted it
Awww Ben!
The secrets out now :wink:
SiJ
Post by SiJ »
Blade forks are not too bad to install but you'll need the clipons as ben said and also to relocate the horn. You'll probably end up getting them revalved anyway as while they're better than standard vtr ones there still not the greatest. Be careful if you fit taper roller head bearings too!
See Shaun Pallisters VTR site for detailed install instructions.
As far as tyres go stick to the 180's. 190's slow down your turn in speed and you also get less contact patch on the tarmac. Its because 190's are designed for 6" rims so the vtr's 5.5" rear hoop means the tyre is pinched. This is why it didn't look any bigger Essex!!!
Si
SuperWheelie996
190's
Post by SuperWheelie996 »
The 190 Parrelli Diablo Corsa is nice. Its on sale at the moment also, at the site below.
http://www.motorcycle-superstore.com/it ... division=6
Jason Terry
