help
tony.wilde1
help
Post by tony.wilde1 »
this weekend i been replacing cct's with ape manual ones.after hours of fiddling th ebike is now running..but..the left can is hot and the right cold..also it just doesnt seem to be running right..there is power there but not as before..ive checked and double checked all the pipes.valve timing..and wires.im at a loss.anyone help?cheers. :?
cupasoop
Post by cupasoop »
Have you checked to see if anybody has stuffed anything in to the end of the can thats cold? Mind that vtrs have 2-1-2 type exhausts. If one is blocked the hot gas will just exit the other one.
Just a thought from my sunburnt head.
Rich.
tony.wilde1
cans
this is weird.if you put yer hands over the ends the left one pumps out hot gases and the right cold or just warm gasses???dont seam blocked?? :?
Squirrel
Post by Squirrel »
Don't read too much into the difference in heat/output from the cans. The branch to the left (I think) can is partially blocked by the internal piping. If you take it off you'll see.
Regards, Squirrel.
