CCT's
CCT's
New bloke here. Am planning on changing my cct's for manuals asap. I know someone here makes them, Bazza I do believe ??
I'm watching a set on ebay at the mo, which do look good quality items, but if someone here can supply the same things, I'd rather give them the cash, keep it in the family so to speak.
I'll avoid the buy it now button till I hear more
Re: CCT's
Question!!
Just read the relevant page in my Haynes manual about removal/replacement of CCT's, and it doesn't say you need to remove cam covers/ find tdc etc. Whats the crack ?
Re: CCT's
Hello and cheers ! Better to spend the extra time to save grief later on .lloydiecbr wrote:Don't use the Haynes use the manual in the workshop knowledge base section as the Haynes is wrong
Re: CCT's
Lee, I have a set of Bazza's fitted they are highly recommended.
Get in touch with him & get a set sorted out ASAP....Do not follow the Haynes manual it has errors in the procedure!!!
Follow the guide in the Workshop Knowledge base & don't be afraid to ask questions.
Mac
Mac
Re: CCT's
you anywhere near colchester?? we are having a workshop day where (with a bit of help) i,m supposed to be doing mine. ( if its not raining)
the thread is called essex workshop day or something close to that
Re: CCT's
Not too far away, I suppose about 40 mins at a guess. Sounds like a job that requires more than a couple of ring spanners, and not sure that i'd want to be carting all the required tools with me on the bike. Would still be interested in attending, just to get the heads up. Is it april 7 ??lumpyv wrote:you anywhere near colchester?? we are having a workshop day where (with a bit of help) i,m supposed to be doing mine. ( if its not raining)
Oh, and hello Lumpy !!
Re: CCT's
Re: CCT's
No worries with fitting these on the day, but you'll need to have them available.
Don't leave it to the last minute; they're always in short supply.
Lastly loosen off the centre (larger) inspection cap on the alternator cover- it gets stuck pretty often.
At least if you do it beforehand you can have a spare one to hand if necessary.
Re: CCT's
Think I'm gonna do them this weekend, time permitting. While I'm at it going to balance the carbs, new oil, plugs and filters, treat the old girl.tony.mon wrote:No worries with fitting these on the day, but you'll need to have them available.
Wish me luch with the cct's, never done them before.
Re: CCT's
Lee,leevtr wrote: Think I'm gonna do them this weekend, time permitting. While I'm at it going to balance the carbs, new oil, plugs and filters, treat the old girl.
If you are going to do them this weekend make sure you follow this link below for setting up the valve timing The link below is for removing and refitting standard CCT's, but the valve timing settings are exactly the same for fitting standard or manual CCT's. Good luck with it,
http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
Re: CCT's
Alright Chris
I already took the liberty of printing your very detailed and easy to understand instructions mate.
Thanks for the heads up though, will let you know how it goes.
Lee
Lee
