Suspension Settings
kiwi_vtr
Suspension Settings
Post by kiwi_vtr »
Hello,
What is the considered opinion for the best settings on my storm ??.
I am a 6 foot 17 stone type, but the rear feels like it has an rsj fitted instead of a shock absorber !!!
MDJ
You need
Post by MDJ »
Phone Roger at Revolution motorcycles. You can find em on the net or on links probably from vtr1000.co.uk they are the poeple in the know according to most on here.
Stormin Ben
Post by Stormin Ben »
Common mistake - Don't try and quicken the steering by adding more preload, your chalfonts will DEFINITELY suffer
I'm on preload setting 2 (from minimum) and have got a 6mm spacer on the rear shock to quicken the steering instead. Its still firm but as good as its gonna get with the standard shock
Ben (6'3" - 14stone + kit)
tony.wilde1
settings for me
Post by tony.wilde1 »
what you think i should set mine to?im 10st10lbs(150lbs).it does seem a bit harsh ..i just thought id ask before fiddling!!cheers.oh and im 5'9".thanks.
kiwi_vtr
Re: settings for me
Post by kiwi_vtr »
tony.wilde1 wrote:what you think i should set mine to?im 10st10lbs(150lbs).it does seem a bit harsh ..i just thought id ask before fiddling!!cheers.oh and im 5'9".thanks.
Given that Roger from Revolution thinks I am too fat(heavy at 17 stone and 6 foot) for standard shocks....you are probably too light !!!
tony.wilde1
thin
yes i might be..ill be the one wearing stirrups so i can stay on the bike!!hahaha!cheers
Stormin Ben
I find that my velcro leather/seat combination works quite well
Only problemis you can sometimes need assitance getting off the bike again!! :P
WRT shock settings, you can try the softest but I found it squatted too much when winding the power on
Ben
MDJ
Hello
Post by MDJ »
I'm 59Kg ish just under 10st I have my Std shock on minimun which works out to give about the right amount of static sag. Rebound damping i've incresed by half a turn and it actually works reasonably now.
tony.wilde1
settings.
again thanks for the advice.cheers fellow light weight :lol:
