rev counter
rev counter
Rev counter has stopped working, what should I check please
- benny hedges
Re: rev counter
check the wiring first.... particularly the small x head screws on the back, connecting the wires to the tacho.
i assume the bike is running ok, pulling ok???
if so it is a tacho fault, not a sensor fault, as the sensor talks to the icm (ecu) then relays to the tacho.
let me know if it is fkt as i have a spare one, but try the wiring first.... probably just a corroded ring connector.
Re: rev counter
Thanks Benny, will have a look over the next few days. It's running fine and pulling like a train!!
Will get back to you if I need to buy your spare
Cheers for the info
Cheers for the info
