Hello all
I am going to change the rear pads on my storm at the weekend
But i have noticed that the piston is quite far out its easy enough to shove back in. But what is the best way to clean it up and keep it moving freely.
For when the new pads are fitted.
Chris
strip the caliper take out the two seals and clean the seal beds and remove any corrosion smear red grease in these on rebuild , clean and polish the piston (auto-sol is good for this ) . and use red rubber grease (can find it on ebay) on the seals and piston when you rebuild it check for pitting on the piston replace if its bad , replace the seals if damaged they are cheep , check the rubber sliding boots if they are ok clean and regrease with red rubber grease , the piston will pop back in easy . bleed and away you go ,easy
Miztaziggy wrote:Clean it with a rag and some wd40
If that fails and it is corroded, use some very fine wet and dry paper and wd40 on it to clean off corrosion.
Put some copper grease on it before you put it back. That's what I did anyway and it worked fine.
dont use copper grease it fooks the rubber up ,
the piston will pop out when you press the brake peddle a few times dont use grips as this will damage the piston .
i also wouldnt use wet and dry on the piston as this will also damage it , just clean and polish it , or replace if its past it
Fine grit wet and dry with WD40 used too wont damage anything, it will very gently get the worst corrosion off as long as you dont go crazy with it and start to sand away the metal. It didnt damage mine...
Though I didnt know that copper grease will damage rubber?!?!
steel wool is best imo... it will get all the crap and light rust off without damaging the piston.
if theyre pitted at all dont bother putting them back in... new ones are cheap enough from silvers or wemoto
Miztaziggy wrote:Fine grit wet and dry with WD40 used too wont damage anything, it will very gently get the worst corrosion off as long as you dont go crazy with it and start to sand away the metal. It didnt damage mine...!
Second that on the wire wool (gently), clean out the seal recesses and replace the seals regardless of condition IMO. Good luck. Dunfermline eh? An Oakley boy maself with family in Dunf. Planning to get up there soon for a walk in the Glen with ma Gran.
Hiya Chris
Went to Inzievar (Mrs Borland's class) but we moved south in the fair holidays of 77, the year I was supposed to go to Queen Anne. Got an auntie up the road from you in Crossford (the Pitfirrane being the local). Next time I'm up, I'll give you a shout.
