Have a look at all the extra bits you get in the US kit.
http://www.dynojet.com/pdf/1185.pdf
Spring slides and extra mains. a little jig to align your extra lift hole. And the price just reinforces the "Ripoff Brittan" regime
I bought and fitted my kit about a year ago and have always found the rear pot to be running leaner than the front as my kit said to fit matching jets, ie 180's in both front and rear.
Ive always thought this odd as the original honda one are different.
Is my kit out of date or is the US spec bike that much different? Anyone Know?
Hi Al,
It could be. Or do you think they v'e just had more complains about the big hole you can get in the power dilivery after fitting their air filter?.
No I think most of there mods are just to reduce petrol fumes and burn off extra unburn't fuel in the exhaust. I don't think that would would make much difference to the differences in the main jet sizes.
Has anyone out there bought a kit in the last couple of months? If so, what did you get in it ?
I don't know if this will make you guys feel better...
I am in the US, and I have the dynojet kit in my bike.
I really regret installing the dynojet kit on my bike. After the kit install, it seems like the carbs fall out of balance much faster. I am no expert on carbs, but my guess is that the drilled vac slides are much more sensitive to the carb balance.
I wish I had just installed the jets and needles, and left the rest alone. I figure Honda has got loads of brainy people that can pretty much design something right the first go.
You know the Austin Powers movies? I have always wanted to date someone like Allota Fagina... but I always seem to date her sister Sandy.
Just had HM Racing of Orpington, Kent set mine up. I have Micron cans K+N filter and 190 main jets which are what the kit suplies. 2 hours set up and it performs smoothly, predictably and produces 109.7bhp at the rear wheel.
MDJ, how do you rate your Microns? I'm starting to get a bit bewildered by the number of cans on the market, but from what I've seen Microns look really well made. Anybody else, feel free to enlighten me with your opinions (please )
They are indeed well built and propely designed and tested to give good power and Carburation characteristics. They are well priced to boot and polish up LURVELY...... The noise level is not too excessive either (unless you cain it )
BTW : 190 jets, needle possition 4 and drilled slides.
Anyone know what the effect of the drilled slides would be ? Del?
Belatherathon? what the hell are you talking about matey??? Don't you mean poorly set up kits wombles your bike up? Investing in correct set up is the important bit..
