Page 1379 of 1497
Posted: Sat Jun 12, 2021 5:25 pm
by jbf955i
Forgot picture, too much beer.
Posted: Sat Jun 12, 2021 8:33 pm
by sirch345
gilson wrote: ↑Sat Jun 12, 2021 1:05 pm
sirch345 wrote:gilson wrote: ↑Fri Jun 11, 2021 8:29 pm
Naughty and sexy... Will try it on Tuesday evening at Snetterton. It's going to be dry!
Bling bling I like
That should be a mod worth doing, not just looking great.
A lot of fork stanchion showing above the top yoke
The forks have been Rodgered which are supposed to be showing 5mm above (seems more like 7mm). After having the oil and seals replaced my mechanic put them back as they were. It turns in very rapidly, I almost tucked the front going for sound check
. It took some getting used to but after a lap I like it a lot. The front gets light on acceleration and a little shake but that makes me feel like a pro!
I was cursing Brexit when looking for the best price. On ebay, direct from Italy, they were very reasonable. Bought it from a UK shop in the end to avoid all the taxes.
They look a fair bit more than 7mm above the bars to me, although sometimes photo's can be deceiving I know
If it works for you which is it sounds like it does, then all's good
Posted: Sat Jun 12, 2021 8:34 pm
by sirch345
jbf955i wrote: ↑Sat Jun 12, 2021 5:24 pm
Hi Guys. I haven't done anything to my today what I have done is, sat in the garden, drink loads and looking at it. Front cylinder will be back soon and away I go
Good news on the front cylinder head
Posted: Sun Jun 13, 2021 6:02 pm
by MacV2
More fiddlin to Blonkey just minor bit's n bobs...
Mainly spent the morning working on the rusty tank from Rusty The Storm, took the sender unit out & the petcock,got as much of the remaining syrupy,rusty fule out.Then made a blanking plate for the petcock hole & chopped the rusty remanants of the sender unit off to use the plate to seal up the hole for that. Flushed it with water to check it was water tight...
Sloshed the water about & drained that out with loads of rusty flakes.
Tomorrow I will get the rust treatment on the go & see if that sorts it out so I can use it...
Blonkeys tank is ok but is covered in under seal & has two of the three tank cap bolts snapped so isn't really safe to use...
Posted: Sun Jun 13, 2021 6:18 pm
by mjvw
Have removed the Blue Flames and put the OEM's back on no carb farts no pop back on decel,carbs balance running sweet. Going to get a baseline to start from perhaps purchase some second hand carbs to set up for the blue flames etc or may sell the BFs at a reduced price. One step forward two back
Posted: Sun Jun 13, 2021 6:49 pm
by uk13iker
Another 150 miles today on new one just 100 more until first service loving the bike just don’t like the sound on motorways ears bleed really need to invest in ear plugs
Posted: Sun Jun 13, 2021 8:03 pm
by grumpyfrog
Almost there Lee, then you can full open her up. Lovely engine in there.
Posted: Mon Jun 14, 2021 1:45 am
by mik_str
Put gas in mine, and rode it. Jeezus I love my bike. Feels really odd not having anything else to do to it, lol (OCMD withdrawals)
Posted: Mon Jun 14, 2021 8:49 am
by Kev L
You won’t stop! There’ll be something
Posted: Mon Jun 14, 2021 1:46 pm
by AMCQ46
Kawasaki little & large catch up on Friday for a shandy.
Posted: Tue Jun 15, 2021 9:38 am
by MacV2
Blonkey Tank update...
So yesterday having made sealing plates for the tank the previous day I used the rust treatment stuff I'd bought on the tank off Rusty the Storm.
Filled the tank up with hot water bunged the treatment in topped off the tank, put the cap on & left it to do it's work...
https://www.rostio.de/shop/picture-galery
This morning I tipped out the tank of the gloop, seems to have done an OK job. Instructions say rinse out with clean water. Had to do 3/4 tank fulls before it came out clean. Then use an emulsion stuff to swirl round the tank to prevent re rusting, empty that & leave to dry.
Seems to have done an Ok job, there are a few bits of lose rust in the very depths of the tank.
I've orderd a new tank filter frtom DS...48 bloody quid...Although I might get some in line fillters & run them for a bit instead...
Posted: Tue Jun 15, 2021 4:21 pm
by Rev. Steve
Put the seat unit on to see if I like it in white, it's silver on the v5, painted in yellow emulsion by previous owner so i bought a set of red fairing plastics but they're 3 different shades.
Posted: Wed Jun 16, 2021 4:01 pm
by freeridenick
gilson wrote:Naughty and sexy... Will try it on Tuesday evening at Snetterton. It's going to be dry!
Very nice and that reminds me, I need some 6mm low pressure brake hose for my MC reservoir.
Posted: Wed Jun 16, 2021 6:42 pm
by TaxiDriver
freeridenick wrote: ↑Wed Jun 16, 2021 4:01 pm
Any more details of your Brembo setup?
Posted: Wed Jun 16, 2021 9:00 pm
by gilson
TaxiDriver wrote:freeridenick wrote: ↑Wed Jun 16, 2021 4:01 pm
Snetterton yesterday evening was brilliant. Beautiful weather, not busy and with five mates in the same group. We even had our own garage. No crashes either.
In addition to the MC I fitted SDS race pads. Braking was much improved hitting about 130+ on the back straight and trying to leave it to the 200m marker to brake was fun. I had to use the run off on the last go, but that's what it's there for. High speed braking is a skill that I haven't really practiced in anger before.
BREMBO 19RCS CORSA CORTA Radial Brake Master Cylinder
I adjusted the RCS settings but never adjusted from the 19 setting. Next time.
Best track day yet.
