Ok here,s the story,
Had the forks revalved by K-tech over the winter & also fitted a 43th tooth sprocket,Now i know the sprocket shortens the wheelbase,
But between 80-100mph on quite soft bends the front end starts to weave a bit & it feels like it wants to tuck in, The front tyre is an 010 with plenty of life & the pressures are ok,
So grateful of any remedies one could try before the sun starts to shine properly
Dom
weave
Dom
One of the causes of this is head bearings that are too tight.
I forget the other cause(s), but I have a suspicion that your rear suspension has something to do with it. Hopefully someone else will know....
- Ian in EnZed
(Red 97 FireStorm with Dynojet kit, APE camchain tensioners, bafflectomy+ploogs, UniFilter, GenMar risers, Avon Azaros, 90/130W headlight, digital clock/voltmeter), Braided s/steel lines.
