Disk Skimmed
Disk Skimmed
Any one recommend a good place to get a disk skimmed.
Front right disk is causing a judder through lever and bars.
Took it off and measured with a micrometer, lowest point is 4.21mm and hightest point is 4.29mm(measured at centre of brake rotor).
Left hand disk is with .02mm all the way round.
TIA
Robb
'97 Firestorm
TIA
Robb
'97 Firestorm
I don't think that the disks have enough meat on them to get them skimmed, but they can be straightened, with a little care, a dial gauge, and a fecking big spanner (you can also take them off, put them on a very flat hard surface, and beat the crap out of 'em).
- Ian in EnZed
(Red 97 FireStorm with Dynojet kit, APE camchain tensioners, bafflectomy+ploogs, UniFilter, GenMar risers, Avon Azaros, 90/130W headlight, digital clock/voltmeter), Braided s/steel lines.
Oops - my bad! I've read so many posts on various forums about warped disks, I immediately assumed that's what you meant.
Any decent brake place should be able to do them, as long as they have one of those rigs that adequately cools the disks while they're being machined, so they don't end up warped after all.
On the VF500 I had a few years back, the right-hand caliper had stuck a bit, and that disk was badly worn. I took it to a brake place, and the techo (coincidentally a biker) would'nt machine them, as he said bikes have so little meat on them that once they're at all worn if they're machined they end up so thing that they're liable to crack, shatter, or badly warp when used in anger. I ended up buying some secondhand NS or NSR250 disks which were identical in size, but drilled rather than plain. Worked a treat.
Good luck - hope you find a suitable brake place.
- Ian in EnZed
- essexbloke
- essexbloke
in my personal experience, they're much better. Have better stopping power (better bite), although they are reported to wear the pads much quicker due to rough sharp edges.
It's also reported that they disperse heat better, negating warping.
Apparently they're better for good stoppies too, (my cahoonas aint big enough for that though)
I'd reccommend them over standard any day, and as i said, they're universally cheaper than standard too.......it's the way forward....
oh and yep, they look nicer too.....
- essexbloke
- essexbloke
