Ro ger Ditchfield
Ro ger Ditchfield
Well long time since wrote on here But the time has come !The bike is getting the wonderful tuning of the Supoerman himself Roger Ditchfield: Full Stage 2 race tune!!!!! God i am looking 4ward to getting back on the "beast" when Roger has worked his magic
STAGE 2 Moriwaki Storm Moriwaki Engine Rebuild Pistons Cams Valves etc Moriwaki Air intakes.Air Filter Mod
Full SAMCO race hoses; Lightened Fly Wheel Dynojetted; KN Filter; Moriwaki Exhaust Moriwaki Carbon Belly Pan Titaniam Nuts & Bolt WP R Shock
Re: Ro ger Ditchfield
So what's he actually doing?
Cams I assume and head reworking?
Right here goes !Remove & Reinstall Engine ito Rolling Chassis,Stri & Rebuild Engine Installing these Parts
Main Bearing Shells Conrod Shells Moriwaki Hi Comp Piston Kit piston ring Set Moriwaki ST1 Camshaft KIt Exh Valve Guide oil Seals Inl Valve Guide oil Seals All valve Collets All Shims All Gaskets and Oil Seals
Lap in camshafts Adjust valve Timing too optimise Camshafts Hone Cylinder Bores Modify Crank Cases And also Fit a FIREBLADE front end with Spondon Clip on s Think thats most of it ! CANNOT WAIT !!!
Re: Ro ger Ditchfield Work Done Part 2
Sorry missed out this SKIM CYLINDER HEADS POLISH VALVES LAP IN VALVES POLISH COMBUSTION CHAMBERS RE CUT VALVE SEATS PORT & GASFLOW CYLINDER HEADS AND MATCH INTAKES STRIP & SERVICE CARBS FIT MORIWAKI AIRSTACKS
INSTALLL DIFFERENT PILOT JETS, MAIN JETS & NEEDLE SETTINGS MODIFY AIRBOX FIT CBR 600 FUEL PUMP LIGHTEN FLY WHEEL DYNO TEST SUPPLING CHARTS THATS iT (i think )
I'm interested to find out what it'd cost for a suspension overhaul at revolution. Heard nothing but good things
Enjoy
Enjoy
SP1's rock!
Just give Roger a call he`s the nicest man you could ever meet ;
- benny hedges
got to agree with that - give him a ring 07970 915259 is his mobychris56 wrote:Just give Roger a call he`s the nicest man you could ever meet ;
Dare I ask how much this very necessary work is likely to cost?
- benny hedges
depends how far you want to go.
i'm sure i remember someone was quoted 300 for the front forks reworked & set up for the rider???
if you want a penske rear shock add another 5 1/2 hundred, and if you want a full ohlins cartridge front end you best go see your bank manager lol - cheaper to buy a duke
afaik they start around 2400!
So go on then, i,m interested as my engine has thrown a shoe. No really it has, vibrates like hell now when pulling off hard.
Been thinking , do I just get another engine and get it swapped over or do I try and find some one like you mentioned to see how much they can do it up for. She was running perfect till I had an oil leak, Only done 23000.
There are two states of tune to the standard front forks. The "road" tune is about 275 and the "race" tune is 350, IIRC. You just have to speak to the legend. He'll be only too happy to give you the details and if you don't buy from him, he'll be absolutely OK with that.benny hedges wrote:depends how far you want to go.
He's currently working on my bike too. There's nothing Roger doesn't know about VTRs.
No bike (yet).
You will be so happy with that bike. Good on you...chris56 wrote:Well long time since wrote on here But the time has come !The bike is getting the wonderful tuning of the Supoerman himself Roger Ditchfield: Full Stage 2 race tune!!!!! God i am looking 4ward to getting back on the "beast" when Roger has worked his magic
No bike (yet).
So are you going to puyt that lovely Moriwaki bike back on the track ? I was lucky enough to see it when i dropped off mine
What a Bike you have there !! OOOzing pure power and quality
- benny hedges
when you pick it up, ask him about the one that fell off the bench!
Benny Hedges ... .Would you happen to smoke benson & Hedges by any chance
