Frame sliders
Frame sliders
I have been searching all over for any "reputable" company that sells frame sliders for the vtr1000f. Is there one or do I have to custom make one?
- firestorm_al
- Site Admin
- Contact:
"Crash Bungs" are the things that lookg like skateboard wheels that you get to mount on the bike that stick out at either side.
See teh pictures on the following page for more details -
http://www.imajoos.com/gallery/vtrcrash/index.html
The ones there are made by a company called R&G. http://www.rg-racing.com/ In my opinion they are the only ones worth getting for the VTR as they mount directly onto the engine mounting point and do not use any kind of bracket to offset them so that you don't neet to cut the fairing.
Al.
Al.
Ah then yes, we call them frame sliders here in the states but it is the same thing. Thanks for the link. I have been pulling my hair out trying to find a manufacturerfirestorm_al wrote:"Crash Bungs" are the things that lookg like skateboard wheels that you get to mount on the bike that stick out at either side.
Al.
- firestorm_al
- Site Admin
- Contact:
I may have not been very clear there. Yes, you do have to cut the fairing to fit the R&G ones so that the crach bung is in line with the engine mounting.WayneM wrote:Eh? How you manage that then?!? I had to drill holes in my fairing to get the R&G ones on - I do hope I havent put them in the wrong place!
Most, if not all, of the others require you to fit a bracket onto the mounting point. Theis bracket sits in line with one of the frame spars and rests on it in most cases. The slider then fits to the bracket above the fairing to it does not need to be cut.
I am not a metalurgest so I don't know much about the strengths of the materials involved but I would suspect that it wouldn't take much of a fall to bend the bracked and push itself against the frame spar thus bending it. Therefore the only crash bungs worth fitting, IMHO, are the R&G ones.
Al.
I would think that the ones that go on the actual mounting bolts of the engine would have the bad point of being able to bend the frame or the engine bolt. The ones that have a bracket would have the advantage of the bracket bending instead of the frame, if pulled away from the frame or if pushed into the frame they would spread the impact out over a larger area. I don't like cutting the fairing, and on the VTR where the engine mounting bolt is and the hole needs to be cut it looks to me like you would be left with very little fairing at the top edge, is that true Al? Has your fairing cracked at that point?
I'm looking for crash bungs/frame sliders/crash protectors as well. I ordered a set of the Harris ones, and they took two weeks to inform me that they are not making them anymore. The still make the bike, people still crash them (I saw a guy crash into the wall at Sendai Highland at about 200 kph two weeks ago) why would they stop making them?
Well how about some of the other bracket types?
Cheers!
Cheers!
"Not all who wander are lost."
-J. R. R. Tolkien
-J. R. R. Tolkien
- firestorm_al
- Site Admin
- Contact:
I can't afford a set at the moment becuse my engine went pop! I'll hopefully be getting a set next year as I'd like to do a few track days.
The R&G sliders actually replace the engine mounting bolt with a longer one for mounting the sliders. At the pint of impact on the bike there is a big lump of engine behind the frame mounting point so the frame sould be ok. Where as there is nothing behind the frame spar on the other types so there is a much greater risk of bending the frame in my opinion.
The other thing about the likes of the harris ones is that you need to remove the castled nuts from either side of the engine. Those nuts are set to quite precise torques using Honda tools so I don't fancy removing them. The R&G sliders are designed to absorb as much of the initial shock of the impact as they can. I still don't like the idea of one of those bracket mounted sliders twatting the frame.
If your worried about the fairing then you could always re-enforce the small area above the slider with some car body work fibreglass?
Al.
Al.
Thanks for the info Al, I did not realise that the "castle nuts" had to come off to put the bracket type of bungs on, I would not want to do that, you are correct.
How is your fairing holding up, no cracks?
Cheers!
PS, do you think the Moriwaki bungs would be any good??
Cheers!
-J. R. R. Tolkien
-J. R. R. Tolkien
- firestorm_al
- Site Admin
- Contact:
- Stormtrooper
- firestorm_al
- Site Admin
- Contact:
With the R&G ones, the castlesd nuts stay in place. The engine bolt nut is removed from the right hand side and the bolt removed from the left. The castled nuts are there to lock the threaded collars in place that put a specific preload between the frame and the engine. I've got a copy of the workshpo manual so double checked that just to be sure. The installation instructions for the VTR are on the R&G site anyway.Stormtrooper wrote:Looking at the picture, it looks like you have to remove both the castle nut & the actual engine bolt ?
not to mention cutting the faring with the R&G type crash bung.
I personally don't have a problem cutting a hole in the fairing as there's going to be a big crash bung covering up the hole anyway!
Al.
- Stormtrooper
- firestorm_al
- Site Admin
- Contact:
