fitted these recently, all 316 stainless 60mm straight through modeled on the standard cans
new cans!!
- benny hedges
Re: new cans!!
look pro m8, where from???
Re: new cans!!
good old ebay!!!
£51.00
£51.00
Re: new cans!!
i stripped an old set of carbon cans for the baffles though when i went on the wooton basset run!!!
- benny hedges
Re: new cans!!
bargain.
i woul've clicked straight past them thinking they were standard ones.
looking at my vipers earlier, the left one is bent for the first 3"" or so and the bracket that holds the end plate on is a bit fkt, so before i buy new ones i might drill out the rivets and see if i can cut them down a bit
then fit a megafone on the end to make them even louder!!!!
sound off!!!
sound off!!!
Re: new cans!!
benny hedges wrote:bargain.
sound off!!!
i have a tig set, some tube, a vice and a hammer!!!!
and an old proverb that goes thus....... "there is no such thing as doesnt fit.... it just doesnt fit yet!!"
- Pete.L
Re: new cans!!
Sweet Fritz
That should give you a sort of presence on the road. No excuse for the cagers not hearing you.
Do you think you'll need a rejet to compensate for the bigger bore?
