Apparently sitting in a rolling road block with 20,000 other bikes isn't good for em...
So Wemoto has a range of options from 70 quid to 150. Is there a good reason not to get the Kyoto kit (cheapest) or a good reason to double that on a kevlar all singing all dancing kit? Nowt wrong with the metal plates (as far as I know..) so no point in replacing them, yes?
Chillitt wrote:Apparently sitting in a rolling road block with 20,000 other bikes isn't good for em...
I only had two friction plates worn on my SP.
I replaced them with original Honda- £8-51 each less than £20 and problem sorted
Your steels should be fine but I would take all the plates out and inspect and measure the lot. Could save you a lot of money.
Cheers chaps. This has just got slightly more complicated because the landlord wants the patch of land my shed is on for next doors garden... Its 10ft square, insulated and lined and all wired in. He wants to put a sling under it and pick it up.....
The sooner I win the lottery and dont have to put up with nonsense like this the better.
