![Red Face :redface](./images/smilies/redface.gif)
Dead as a dodo
Dead as a dodo
Just changed the rr to a r6 one charged the battery last night stuck it on the bike today nothing no light nothing at all , :mad2 got 13 volts at the battery but nothing anywhere else checked all fuses all ok and the earth from batt to frame all ok any idea,s folks . Even if the battery was low the lights would come on the only thing I can think is that I have disturbed somthing as the bike was turning on ok and running before I started. ![Red Face :redface](./images/smilies/redface.gif)
Re: Dead as a dodo
Kill switch prob would still let the lights work, surely?
But if you've just changed the RR then I'd suspect a diode wired the wrong way round, something on the connections, anyway.
Try disconnecting the rr, then seeing if it will crank?
Or might be worth putting jump leads on from another 12v vehicle and seeing if it's current not voltage below par.
Re: Dead as a dodo
Gotta be as Tony's reply shirley?
Have you seen this page? http://vtr1000f.wickidnet.com Probably teaching you to suck eggs or however that w@nky saying goes but just in case not...
Good luck
James
Good luck
James
Re: Dead as a dodo
Well took the r6 reg off and put the honda one back on still dead can only think that its taken my new battery out as well S**T .Thanks gidsy yes I looked at that and made sure it was all correct, feel like throwing the bike in the skip at the moment and the new reg went in perfect I knew it was going to well :mad2 :mad2 :mad2 :mad2 :mad2
Not sure what to do next![Sad :(](./images/smilies/icon_sad.gif)
Re: Dead as a dodo
where bouts are you balls, ive got a spare storm battery in me garage,(just incase!) kept on an optimiser
jumping it off a car will tell you if its just the battery
![Wink :wink:](./images/smilies/icon_wink.gif)
Re: Dead as a dodo
If your local to Manchester i could have a look for you Got 10 years experiance with car electrics and not bad with the old storm wiring loom too. ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
Re: Dead as a dodo
Thanks for the offer m8 sadly I live in penzance cornwall wich is along way from everyone and everything apart from chris ![EEK! :eek2](./images/smilies/eek.gif)
Re: Dead as a dodo
its a while since i had the storm now but i seem to remember it having a fuse on the starter relay which kills everything,just a thought ![Confused :confused](./images/smilies/confused.gif)
Re: Dead as a dodo
thanks for that I saw that today will
have a look at it again I think is around 30 amps that fuse ![idea :idea:](./images/smilies/idea.gif)
Re: Dead as a dodo
battery terminals tight?
corroded or broken connectors?
sidestand switch?
feel your anguish, the only thing that keeps me sane is the St Austel brewery when we go to the MiL she moves down there so often I dont know where she is actually at the moment!!
sidestand switch?
Re: Dead as a dodo
Will have a look at the sidestand as well thanks m8 . Cornwall is ok but if you need anything other than a turnip or other vegtable then your out of luck ahh maybe im being to hard on the county mmmmm NO IM NOT ![Laughing :lol:](./images/smilies/icon_lol.gif)
And I was born here.
Re: Dead as a dodo
If it turns out to be the sidestand switch, DON'T buy one, I've got several spares.
Let me know.
Let me know.
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
Re: Dead as a dodo
OkOk I hold my hands up in shame the main fuse had blown my fault for trying to work in the gloom of my garage , but at least it is not a dodo any more with a healthy 14.4 volts coming out of the r6 unit . I think this mod should be done as soon as you get your storm its not worth the hassal keeping the honda unit as you know it going to fail thanks for all the help people this place must be one of the best on the net thanks again
