Mike, I think you said you painted your tail/seat plastic's on your Firetsorm using Halfords rattle can spray paint (as below). Did you need to lacquer the paint once you'd painted it
Thanks for the info and paint link Mike
I thought your seat plastics looked pretty good in the pic, so I was wondering if you had lacquered it for future reference IE. if I see a hugger or belly pan for sale and I need to re-paint it I'd know what to do.
Use RS paints for a perfect colour match, I would recommend them but they are pricey. http://motorbikepaint.co.uk/
Touch up kit for Red Storm was £10 - for that you get 3 X 20ml bottles, one of ground coat, one of top coat and one of clear coat (laquer). Oh and a set of instructions.
I thought that was pretty reasonable considering the cost of 1/2 litre of colour matched single coat stuff.
Haven't seen him there before, but at least he has website. Seems to cover the whole spectrum (get it )
I’ve used these chaps in the past
colour match was pretty good, fast delivery and not a bad price luckily I’ve found a paint suppler locally that’s sh*t hot at matching so now use them as I prefer the 2k system http://www.paints4u.com/
Just finished re-spraying a side panel using the Halfords Y124 shining Pearl Yellow.
Colour match is good, (took two full cans though) and I then lacqured with spray can standard stuff.
The finish is different, maybe I should have flatted it between each coat?
It's not exactly dimpled, but you can see that the original is gloss and my effort seems more of a vinyl finish.
Mind you, never bothered to spray anything before, so maybe I should have left it to the experts.
It'll do for now.
Also my first time of trying to repair cracked plastic using an old soldering iron- that seems more successful, but in hindsight I should have used a bit of body filler and smoothed it before spraying the colour on.
Looks alright from a distance, under the cover, in the dark, if you squint.
baldrocks!
Tony, the earlier Yellow is one of the most difficult colours on the Firestorms to match, so if you got a good result that's excellent
To get a good finish (shine) on the lacquer, once you've given it time to harden off, you'll need to buff it up, either with polish, T cut or a cutting compound, or all three. Be very careful though on non flat surfaces not to rub through to the paint,
