Awesome
http://www.bikechatter.co.uk/forum/show ... 49#post249
cheers
leigh
The Tampon Gun
- Contact:
- storminateacup
hahahaah that was well funny,
we used to make potatoe launchers when i worked for a place that made those air tubes in shops n offices to carry cash or paper long distances in a vacum tube..
the mini launchers would fire a potatoe well over 300m.. thats only an estimate cause the fired in the air and never seen again...
- Stormin Ben
When a skinny apprentice I found that if you plugged a whole 100m coil of airline hose into an airline at 100psi after you've filled it with 1/8" cap head screws it fires like a machine gun.
Also made bolt bombs with BROWN matchheads. They're absolutely safe until you heat them..........try it with small bolts first, 8mm makes a satisfying crack.
Mmmmmm satisfying crack.....
