Ducati 750ss First time project
Re: Ducati 750ss First time project
Do like those exhaust, really suit the look of the bike
Maybe I Don't Like Your Bike Either!
Update Jan 2013.Headlight
Earlier in the project I designed and made my own headlight bracket:
However it needs some adjustments, which takes time
So in the meantime I have purchased some ready made brackets
I can get on with other things to make the bike roadworthy, then make a new bracket later
Not the right look though
- agentpineapple
i think it looks ok mate, but you know what you want, when do think the bike will be road worthy?
Thanks Marty
I would hope to complete it before I die
Or by this summer
Or by this summer
Your just want to beat marty's record I prefer the Black brackets you've fitted but that's just me. You obviously have an overall look that your envisioning.
- agentpineapple
tell me about it mate, mines about to run into the 3rd year, although it was running for most of last year....Flatline wrote:Thanks Marty
Or by this summer
- agentpineapple
i still hold the record for fastest single cylinder firestorm at brands hatch......MacV2 wrote:Albeit on one cylinder !bigspanishmarty wrote:
Update Jan 2013.Various
Stripped down the front calipers
Spraying the footrest hangers in the paint booth
Cut the frame at the end
Shaped some frame parts to make the "V"
You may remember I bought some indicators to fit in the end of the frame: Voila!
Will check what it looks like with the frame joined to the end rather than as a "V"
Loving the paint booth. You just need a couple of hairdryers poking through the sides. Don't worry about extraction as fumes are good
Keep up the good work Flatline
Maybe I can get it ready for the ride out in May
every little helps
25mm Steel tubing needed for cafe racer project
I need some tubing for the cafe racer project
The frame is 25mm which I am finding it hard to source
Anyone know where I can get a metre of the stuff?
