Will you be able to keep the rust at bay for that long?....Pete.L wrote:Now all I have to do is find time to ride it and get the front done
Probably sometime after I recover from Ian's carpet!!!
Plans for the winter?
- KermitLeFrog
Re: Plans for the winter?
very nicePete.L wrote:
Stage one complete. Rear shocker fitted. Now all I have to do is find time to ride it and get the front done
- Pete.L
Too lateKermitLeFrog wrote:Will you be able to keep the rust at bay for that long?....Pete.L wrote:Now all I have to do is find time to ride it and get the front done
Well it is a Suzuki LOL
- Miztaziggy
Carpet burns?Pete.L wrote: Probably sometime after I recover from Ian's carpet!!!
Ooo err. What have you two been doing?
- Pete.L
Shhh! Don't let everyone know I'm easy ......
Well, not as easy as some!
- KermitLeFrog
A little one in front and a skinny one from behind. And Stuart preparing himself. What more could you want?
And Phil looking bemused.... (nothing different there)
Al looks very gay in that picture
cybercarl wrote:Al looks very gay in that picture
lmfao. briliant picture that
Let's see... apart from snowmobiling ( ).... my bike plans are:
- remove carbs and replace butterfly screws with low-profile units (minor gain to be sure, but hey, it all adds up)
- make a new airbox lid with larger filter area (currently using, with great success, a K&N filter from a late-model Trophy 1200; will now try with the filter element from a K&N for VTR - 50% greater filter area)
- add heat reflective wrap to carbs (fuel bowls, carb body where accessible to do so) and airbox lower - heat is the enemy of intake air density (again, minor gains... but, see above)
come spring time:
- replace tires (or should I say, tyres )
- have valves adjusted and get intake cams (currently Mori Stage 1 exhaust cams) replaced with Yoshimura Stage 1 units (practically same duration, 6% more lift).....
summer plans:
ride!!!!!!!!!!!! (and walk around with a goofy bike-induced smile)
come spring time:
summer plans:
I plan a trip by train to Mold magistrate's court, followed by a winter in a nice warm train all the way to work.
Funnily enough, there is a pub close to both the local station and the work end one, so I may not notice the journey very much in either direction.
Unless I get a year's ban, in which case I shall also sulk,for six months, and may possibly find time to clean a bike, maybe even both if I get bored.
There's always a silver lining
- agentpineapple
shite news tony, I hope you don't get a ban, unless you want a small ban to return to zero points, then I hope you do get a ban....tony.mon wrote:I plan a trip by train to Mold magistrate's court, followed by a winter in a nice warm train all the way to work.
I've already told you...you can get the court hearing moved to somewhere more local...Seriously you should get a brief on the case.tony.mon wrote:I plan a trip by train to Mold magistrate's court, followed by a winter in a nice warm train all the way to work.
See here...http://www.vtr1000.org/phpBB3/viewtopic ... 80#p431732
Ap's correct- I can sacrifice a winter's riding to get back to a clean sheet.MacV2 wrote:I've already told you...you can get the court hearing moved to somewhere more local...Seriously you should get a brief on the case.tony.mon wrote:I plan a trip by train to Mold magistrate's court, followed by a winter in a nice warm train all the way to work.
And if they double my insurance, so what?
It's cheap because I'm old.
Old enough to have cheap insurance, and to remember when a pad change referred to brakes.....
Need to fit cbr 600 brakes
And fix a leak in the left fork leg
