show off your bike
- Squiffythewombat
- Contact:
This is what I did with my headers/downpipes whatever you wish to call themDazjm wrote: On that note, i notice a lot of you have very clean downpipes.
Any way to remove/cover/clean that used rusty worn look of the downpipes?
http://www.vtr1000.org/phpBB2/viewtopic ... pit+polish
- RedStormV
- Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
- Contact:
Dazjm,
As Chris has said, good old elbow grease and a bit of polish.
Wire brush (manual or drill) and wire wool if they're really bad.
Then abrasive / polishing wheels - ideally a bench mounted buffing wheel / gringer, but if not then an electric drill - which you'll probably need anyway for the tight spots.
You can buy blocks of stainless polish from auto jumbles and the like which are ideal for the job and last a lot lot lot longer than a tube of autosol.
Alternatively if you know someone who works for an enginnering company, fabricators, sheet metal working etc you might ask them to do the job for you as a guvvy for a few quid.
And as Chris also says, the stainless used for the downpipes is crap.
Cheers,
Graeme.
Cheers,
Graeme.
- Stormin Ben
Nooo!RedStormV wrote:As Chris has said, good old elbow grease and a bit of polish.
Dont whatever you do use wire wool or wire brush -you'll strip off any of the stainless coating thats left
If you've got the patience then the polishing/ autosol method gives the brightest finish (for a while)
I used the green scouring pad and plenty of wd40 (brilliant all purpose muck shifter by the way)
Came up really well and is also lasting well too
But its not a very good one!
- Stormin Ben
Like that colour a lotclayderman wrote:Here's mine, doesn't seem to be that many blue ones about
And thats big praise indeed from someone who owns the best colour VTR
Its got a new bellypan and different tyres on now but other than that its unchanged from this shot
Probably hasnt been cleaned since this was taken either
