Page 1460 of 1502
Posted: Thu Jan 12, 2023 9:13 pm
by sirch345
MacV2 wrote: ↑Tue Jan 10, 2023 3:19 pm
Took The Murvinator for it's MOT...
Passed no issues... Apart from it hissing down on the way there, all the time I was there & of course on the way home...!
Tucked it up in the cave, It might be dry tomorrow so I'll give it a wash...
Could be worse the road could have been all salty but it's been too mild for that shite to have been spreading...
Back at home post drenching...
Always good to get the mot out of the way for another year
Posted: Sat Jan 14, 2023 2:06 pm
by lloydie
It’s running again , 14.5v at tickover
No leaks with the new seal kit in the carbs
Posted: Sat Jan 14, 2023 6:25 pm
by Kev L
Well done Lloydie
Posted: Sat Jan 14, 2023 7:51 pm
by sirch345
lloydie wrote: ↑Sat Jan 14, 2023 2:06 pm
Good work Lloydie
Posted: Sun Jan 15, 2023 4:37 pm
by fabiostar
Stuck a new battery in the Pegaso, ten mins tops then 2 hours to get the clock reset
Posted: Sun Jan 15, 2023 5:51 pm
by tony.mon
fabiostar wrote: ↑Sun Jan 15, 2023 4:37 pm
Just remove the battery then install it at the time set by the clock...
Posted: Mon Jan 16, 2023 8:40 pm
by fabiostar
tony.mon wrote: ↑Sun Jan 15, 2023 5:51 pm
lol it near came to that
then the toggle switch decided to work
Posted: Wed Jan 18, 2023 12:27 pm
by lloydie
Thought I’d treat myself to some better carb balancers .
Didn’t take long to get all 4 a lot closer , great but of kit
Posted: Wed Jan 18, 2023 8:14 pm
by sirch345
The new carb balancer seems to have worked out very well
Posted: Thu Jan 19, 2023 4:21 am
by lloydie
sirch345 wrote: ↑Wed Jan 18, 2023 8:14 pm
Thanks
wished I picked up a set of these years ago as they make it a lot easier
Posted: Thu Jan 19, 2023 9:57 am
by tony.mon
I use these, too. The only additional advice is to check after they're set by opening the throttle and letting it snap shut a few times as they can settle after setting.
Posted: Thu Jan 19, 2023 1:22 pm
by lloydie
tony.mon wrote: ↑Thu Jan 19, 2023 9:57 am
Thanks Tony , I did just that after every adjustment
Posted: Sat Jan 21, 2023 2:11 pm
by lloydie
Fitted a usb port for satnav ,I wired it into the old power feeds from the Reg/rec .
Started to make mk2 reg/Rec loom as the new maxi fuse holders came . Just waiting on reg plugs to come , I don’t think it’ll be needed tho but it’ll be good to keep as a spare in the boot if the one fitted melts .
Posted: Sun Feb 05, 2023 3:07 pm
by lloydie
Put it all back together with a rear rack and different tank as the other one had rusted . 50 mile shake down run and all is well except a body work rattle at 4K !!!
Few jobs to do and it’ll be ready for Devon
Posted: Sun Feb 05, 2023 8:17 pm
by sirch345
lloydie wrote: ↑Sun Feb 05, 2023 3:07 pm
Well done Lloydie
