![Cool 8)](./images/smilies/icon_cool.gif)
I like,
How much up and down movement between the cam sprockets did you give the cam chainsmjvw wrote: ↑Mon Mar 21, 2022 6:26 pm Started bike up for first time since coolant hoses and manual ccts fitted, she started after 5 stabs at the button.
No rattles as such, ran up to temp topping coolant and checking oil no leaks all good.![]()
On start up from running temp a screech on turnover then disappeared I belief this the manual ccts being a little tight.![]()
Need to check again from cold tomorrow to replicate, question is how I deal with the problem have read so many posts on the subject head is in the shed.
Any advice will be well received.
I would suggest backing out the adjuster on one cylinder first one or two flats, if you were able to tell which cylinder you heard the screech from then do that one first. You want to do that when the engine is stone cold, so if the first cylinder you go for doesn't cure the screech try the other one the next day so the engine is cold. Good luck,mjvw wrote: ↑Mon Mar 21, 2022 9:05 pm Locked 0EM off using lock of key rear first TDC then front TDC measured and set manual ls up to that setting checked motor turned ok no issues.
As per instructions provided with purchased ccts and site instruction but did not measure chain slack.
Was hoping could back them off without removing cam cover as all new gaskets and cam bolt washers fitted.
Thanks for the help.
Thanks Chris will do.sirch345 wrote: ↑Mon Mar 21, 2022 9:49 pmI would suggest backing out the adjuster on one cylinder first one or two flats, if you were able to tell which cylinder you heard the screech from then do that one first. You want to do that when the engine is stone cold, so if the first cylinder you go for doesn't cure the screech try the other one the next day so the engine is cold. Good luck,mjvw wrote: ↑Mon Mar 21, 2022 9:05 pm Locked 0EM off using lock of key rear first TDC then front TDC measured and set manual ls up to that setting checked motor turned ok no issues.
I would suggest backing out the adjuster on one cylinder first one or two flats, if you were able to tell which cylinder you heard the screech from then do that one first. You want to do that when the engine is stone cold, so if the first cylinder you go for doesn't cure the screech try the other one the next day so the engine is cold. Good luck,mjvw wrote: ↑Thu Mar 24, 2022 6:49 am [quote=sirch345 post_id=497456 time=<a href="tel:1647899341">1647899341</a> user_id=345]
[quote=mjvw post_id=497454 time=<a href="tel:1647896717">1647896717</a> user_id=15582]
I think I will have exactly the same issue on mine since I low sided as I remember seeing something venting from the front header so stuck my head in the sand and parked the bike up and hid it under some beach towels...can't keep ignoring and put off sorting for much longerMacV2 wrote: ↑Fri Apr 08, 2022 4:40 pm Released Nue Red from its winter hibernation.
Freshley charged battery. Check.
Fresh fule. Check.
Hit the starter several times to pull some fule through. Drained carbs...
Hold the starter & eventualy it springs into life.
Run it up to fan kicks in...All good execpt...
Horrible blowing from the rear header. On inspection the header has dropped down about an inch![]()
This was probably from the Wales slide. I had used it a few times after Wales before putting it in hibbernation & it was probably doing it then but with ear plugs & a helmet on I never noticed it...![]()
Sitting on it today whilst warming it up it was fairly noticeable![]()
So dropped the oil as that was the plan any way, then once it had cooled down a bit further inspection showed the issue, the clamp was a little loose but as the pipe had dropped down it needed to be pushed back up.
This is the Mori Ti system so no graphite gaskets in there...
Gave it a few whacks with the deadblow hammer but it didn't budge... Then![]()
I pinged the springs off to take the tension off & used me trolly jack under the lower part of the header to slowly jack it up, the rear downpipe has a stopper ridge on it, got it bob on, re set the clamp in the right spot tightened it up...& had to wait till the oil was back in before testing it...
Pleased to say all is now good.
Checked all the lights & indis put a bit of air in the boots...Good to go.
Gonna get a ride out tomorrow... probably about £60 worth of fule to look forward to...![]()
Wait till you tie it into your phone and get the full logging data. These are the data points it gives you.
