Page 1382 of 1501
Posted: Sun Jul 04, 2021 8:23 pm
by sirch345
Good man Mac
Posted: Sun Jul 04, 2021 8:26 pm
by fabiostar
christ almighty mac do you ever stop
i went out all guns blazing into the cave, give dori a wax and......................well thats it
im liking this not working at bikes these days, did fire it up and run upto temp then wandered inside to watch the superbikes.
Posted: Mon Jul 05, 2021 4:56 pm
by MacV2
So todays instalment in the saga of Blonkey...
Exhausts on... Slight fight on the left as the stupid footrest bracket was a bit bent so needed some hammer time...
Tank on & all pipes conected. Ignition on to chech that the RLOD works...
Put some fule in, no leaks...
Fired it up & it lives !...
Run up to temp fan kicks in...
Balanced carbs, not far out just a minor tweak...
TPS check it's a smidge over 500omhs so that'll do...
Checked coolent & topped up a smidge...
Cleaned up & put it all away, came in & me fork seals have turned up so busy again tomorrow...
Posted: Mon Jul 05, 2021 8:42 pm
by neil
Cleaned bike up and checked it over. Rear disc is too thin down to 3mm so have to fit one off spare wheel. Found a crack in one front disc so will swap over from spares. Picking up rear tyre tomorrow. Fitted replacement stickers as only tank had them when I bought it in 2003 so only taken me 18 years to do that. MoT day gets nearer
Posted: Tue Jul 06, 2021 2:35 pm
by MacV2
Blonkey saga...
Last thing yesterday I dropped the oil.
So today got the fillter off after a fight...Involving a hammer & large screwdriver as the poxy tin plate removal tools were just spinning...
New fillter & fresh oil...
Forks will have to wait as the poxy ones I ordered came sans dust seals even tho I order a set of both... In contract with the seller to try & resolve...
The dust seals on it are rotten so need replacing...
It keeps raining so after sorting some bits out for Freeridenick I gave up a & came in...
Posted: Wed Jul 07, 2021 9:25 pm
by fabiostar
well again i went out to the cave full of the bull
chucked the tools in the corner ,took dori out and frankly had a ball revving the tities clean of it..
Posted: Thu Jul 08, 2021 4:32 pm
by Kev L
Went out for a ride in the 1960’s !
Cracking ride Grommet!
Posted: Thu Jul 08, 2021 6:08 pm
by AMCQ46
that smile says it all Kev!
Posted: Thu Jul 08, 2021 6:13 pm
by Kev L
Says “I’ve got dementia!” To me
Posted: Thu Jul 08, 2021 6:39 pm
by alanfjones1411
A nice blast from the past Kev.
Posted: Thu Jul 08, 2021 7:25 pm
by Pete.L
Kev L wrote: ↑Thu Jul 08, 2021 4:32 pm
Looks like an absolutely cracking ride out Kev
I still haven't figured out how you can park up in a manky field to take some pictures and not even get a speck of mud on the bike let alone the tyres.
If you dementia eases you'll have to let us know.
Posted: Thu Jul 08, 2021 8:41 pm
by sirch345
Pete.L wrote: ↑Thu Jul 08, 2021 7:25 pm
That's normally because the bike was trailered there. The trailer is probably just out of shot
Great photo's Kev
I hope you had a great ride,
Posted: Thu Jul 08, 2021 9:18 pm
by MacV2
More Blonkey ness... Total strip & rebuild of the forks... Seals & bushing's... even gave the lowers a spruce up...
Did the headstock bearings as the front end was off...Still had ball races so put in some tappered...
Doh moment No.1 found I had a full set of fork seals in the draw...fek knows how I missed them...
Doh moment No.2... Put the forks on torqued up the last bolt, just about to put the wheel in...Forks lowers are handed for the brake mounts & muppet brain had them on the wrong way...
It had started raining at this point & with bike half out of the cave on an abba stand with the wheel out I was a bit distracted...thats my excuse & I'm sticking to it...
Bunged the tail fairing on mainly just to check lights work...
MOT booked for tomorrow PM... Just fairing & mudgard to fit quick check over & should be good to go...
Posted: Fri Jul 09, 2021 11:29 am
by sirch345
MacV2 wrote: ↑Thu Jul 08, 2021 9:18 pm
Good luck with the mot Mac,
Posted: Fri Jul 09, 2021 1:06 pm
by MacV2
Out in the cave early...
Gave the seat plastics a buff up, seat on, buff the tank, mudguard & bikini fairing buffed & fitted. Fairing on, lights checked...
Sideligt bulb out so replaced... Indis plugged in all tested & working, final fit of the fairing...
Right hand mirror all floppy... Pulled back the boot hoping it was just a loose bolt... Of course not the...The botton bit of the mount was missing in action so nothing for the bolt to tighten to...
Raid the spares pile & found another right hand mirror but its not an OEM one but it will do for now...
Heading out for the MOT @ 15.30...
Will report back later...
