Richard wrote: Sun Nov 01, 2020 7:51 am
tony.mon wrote: Sun Nov 01, 2020 2:41 am Sadly a Firestorm is looking to be a very sensible buy as a a winter hack these days, while remaining as good option for a sunny day buy.
Oh god help me, have I reached that stage in life were I am sensible.......... maybe, maybe not!!!! 😈
It's ok, you can still ride it like a complete butt, same as any other bike.
Stripped the donor bike down to a bare engine ready for transplant.
Cleaned the crud of the front and rear callipers on Cruella and got them operating smoothly, then fitted new pads front and rear. Went around it with the spanner’s checking it was all secure. Then started to clean it up a bit, but you can’t really polish a turd
Still just sitting and waiting on back ordered valve springs...... :Ball Kick: :lol:
Operation 17” wheel started
The ktm Has a huge 30mm front spindle , so the 47x25x12 bearings are being replaced with 47x30x9 bearings.
Turned up a 47x 38x3mm spacer to go under the Datum bearing that is held in by the circlip, and will turn up an 30mm ID internal spacer tube, to go between the bearings, that is 6mm longer. That way the outer face of the opposite bearing in the same place as the the out going part.
Just need the steel tube to arrive.
And yes, I am going to have a cast wheel In the front and a spoked one on the backImage.
Do you intend to fit stiffer front springs?
Under braking the front end will compress and the bike's attitude will be more nose down, you might find that the back tries to lift more than normal under heavy braking.
tony.mon wrote: Fri Nov 06, 2020 8:05 am Do you intend to fit stiffer front springs?
I will drop the forks as far as I can through the yokes to lift the front a bit, but a few people on the KTM forums have done it without stability issues
haynesjones66
Post by haynesjones66 »
is that a little ducati i see?
A bit late to say this 8O but what about getting a 17" hoop laced onto the KTM hub so you keep both wheels the same?
haynesjones66 wrote: Fri Nov 06, 2020 6:00 pm is that a little ducati i see?
Well spotted. Yes a 250 Desmo single. It's not mine I am just helping rebuild it
Got the new engine in the race bike. It's not ready to run yet but it's just a case of cleaning the carbs and bolting a few bits on and I can see how a box-fresh stage 2 motor compares with my old one. :D :beer:
freeridenick wrote: Sun Nov 08, 2020 7:00 pm Got the new engine in the race bike. It's not ready to run yet but it's just a case of cleaning the carbs and bolting a few bits on and I can see how a box-fresh stage 2 motor compares with my old one. :D :beer:
Well done Nick, you must be looking forward to that :D
Bearing internal spacer done (top one new, bottom original) and the Disc spacer skimmed down.
bigger of the 2 wheel spacers done to calculated size.
Old lathe doing ok with home made digital readout
Then painted the internal spacer.
Waiting for a few more bits then will commission a special set of ABS rings for both back and front wheels with different number of spokes to compensate for the front rotating faster.
More measuring and spacer making tonight.
Then fitted the 2nd wheel brg now the spacer paint has dried.
Looks tiny with no tyre!!
And started to clean the front callipers but looks like at least one piston has a chunk of the coating flaked off from corrosion, so need to get more sparesImage
And then the joy of refilling the brake fluid on a bike with ABS!
Pentode
Post by Pentode »
That's a lovely little lathe! 👍
Insufferable halfwit.
