boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
Hope you boys enjoy you're weekend up here in Dumfries and Galloway Kirkcudbright is nice wee toon,weather looking to be ok the roads are great fun unfortunately I am unable to join up as working all week end typical .
I have recently (last month) been on St Marys loch road and Moffat beeftub road they had been recently chipped much to my disgust so take care if traveling these roads
hopefully I will meet up with you guys sometime when I'm not working
awgh69 wrote:Hope you boys enjoy you're weekend up here in Dumfries and Galloway Kirkcudbright is nice wee toon,weather looking to be ok the roads are great fun unfortunately I am unable to join up as working all week end typical .
shame you can't make it, we need a few more locals to come out and play.
thanks for the warning on the chipping, hopefully 1 month is just enough for it to be clean
fabiostar wrote:boats all a bit fuked on the booked front . have to get the 15.30 so should be at the campsite about half5/6 then a bit of drinking and dancing to catch up on....cant wait..
time to check your chain
Yep! make sure it's there or we will all be yanking it all weekend long
AMCQ46 wrote:I found an easier solution - I am lazy.
1) don't even bother with Base camp, connect your GPS to your computer and download the GPX track file direct to the zumo. there is an internal folder called GPX, so put the file there.
2) switch on the Garmin and select the "Apps" icon from the home screen, then select" tracks" on that menu.
3) scroll down the "saved" tab and you will find your file, select the file and it will show it on the map.
4) there will be a spanner icon on the top right, so press that and from that menu select "convert to Trip"
5) once this is done the file will appear in your Trip Planner section and you use it as normal from there.
final tip is to disable the "off route recalculation" in the navigation settings - or set it to "prompted" so it wont change your planned route when you leave the path for any reason.
This works great! Who said being Lazy doesn't pay off?
Well done Ali
