- agentpineapple
looking good al, i look forward to seeing them on the bike...
Looks like the forks have little trainer socks on.
ggggrrr feckin annoyed now.... just put a couple of coats of lacquer onto then and it has reacted with the black paint but not the silver..... now have crinkle finish on the lower bits.
i will see how it looks when dry, don't care if it is not glossy as long as it looks like a works racer finish i might leave it
If that's happened was the black paint an oil or water based paint?
abba stand and a scissor jack or prop under the sump
- bigtwinthing
wow love that.
I bet that will be good fun
How annoying, hopefully when dry it won't look out of place too much,AMCQ46 wrote:ggggrrr feckin annoyed now.... just put a couple of coats of lacquer onto then and it has reacted with the black paint but not the silver..... now have crinkle finish on the lower bits.
It's going on a yellow bike Chris, it can't make it any worse! The bottoms look like Lloydies wellies anyway.
looking good Al..... that we supermoto looks great craic.
- Pete.L
Wicked. I didn't realise you were racing it with slicks. No wonder you said it was a great laugh
Aww that is slightly cutting Kev.............................................................................but I like itKev L wrote:It's going on a yellow bike Chris, it can't make it any worse! The bottoms look like Lloydies wellies anyway.
More likely the cold damp weather and applying too much too quick. Fuel resistant lacquer is the worst for this and causing a reaction.If that's happened was the black paint an oil or water based paint?
Stick the can in some hot water to warm it up a bit first and start with very light dust coats, leave for 10-15mins between coats building the amount applied each time. Only on the final coat do you give it a good heavy coating but not so heavy that it runs. Just enough so it covers well and leaves a good finish.
