The last post I can find on this subject was July 03, but here's good ol' me to open it again... Apologies to those of you that have moved on, but I need to know stuff...
Del - did you ever fit the APE replacements? Were they £34 each or was that for the pair?
Del/All - If I understand it right, the OE CCTs are spring loaded, in thoery constantly and automatically placing just the right amount of pressure on the cam chains as they wear to stop them flapping about too much. Is that right? The problem is what? Grooves or burrs or lips from mfg process on the tensioner shaft (or whatever) stop the tensioner moving inwards, despite the spring pressure?
I understand that you have to manually turn the APE tensioners inwards to maintain pressure. How do you know when to turn them in? When the rattle starts? Every XXX miles? How much do you turn them in?
I've been hoping that this problem would miss my bike, but at 23300 miles, I have been keeping my ear open for the noise, and I think it's started (most noticably at lowish revs, slowing down on a trailing throttle, 2nd gear).
I called the dealer I bought my bike from, and he said they did check for any CCT issues when they did the pre-MOT/pre-sale 20,000 mile service, as they were aware that the CCTs can be problematic. They were fine then, but 3300 miles later, he says of course they could be starting to give trouble.
He said to try a VERY VERY GENTLE tap with a light tool to maybe free the tensioner to let the spring pressure it into the chain. He said the biggest probs are when you ignore the rattle till it's too late, and that once you address any noise, you should easily see 40,000 - 50,000 before any attention is needed at all with the CCT or the cam chain itself.
Any response to this would be very welcome - I'll buy the APE items if necessary, but first (and depending on comments from you guys) I might try to tap the tensioner(s) in.
Have a good weekend all.
