feels like fuel starvation ?
Re: feels like fuel starvation ?
Give it a wee dram
not road tested it yet, but it perfectly fits the symptoms, so I have high confidence it will be all OK now
- Pete.L
defined an easy test to prove the diaphragm was faulty that any of us can do.
Before I took the tank off, I got the big syringe that I use for brake bleeding etc and a length of hose. took the normal vac hose off the back of the tap and used the syringe to apply vacuum to the tap .... I wasn't sure what good or bad would feel like, but the result was clear ... I could pull the plunger out of the syringe without any resistance, so the vacuum was leaking away. ... and with the new diaphragm fitted and repeating the test, there was very obvious build up of vacuum and resistance against pulling the plunger.
the kit was from NRP . this was the kit for 16l tank bike .. it has the main diaphragm, a new spring and the rubber plunger part that actually closes the fuel on and off.
That is handy information to know and an easy testAMCQ46 wrote: ↑Fri Jun 08, 2018 11:20 am defined an easy test to prove the diaphragm was faulty that any of us can do.
Thanks for that Al and the link for the repair kit
That’s good to know Al good detective work
to complete the thread for those in the future who have the same symptoms - after a hardcore roadtest in devon, yes the new fuel tap diaphragm fixed the problem no issues with extended Wide open Throttle
After a few pints he was
